Any way to adjust the seat release?
21 RTL is almost impossible to get the seat to release, It takes several minutes to get it open to fill gas. I'm on the right side turn the key to release and try to pull it up. Is there any way to adjust it? It shuts too tight in my opinion.
SpyderLovers Sponsor
First, spray some silicone spray on it, and work the mechanism. I’ll go look at my 22 demo RT and see if there is an adjuster. Joe
Joe Meyer
Are you lifting on the right front edge of the seat? The locking pin is on the right front and if I try to open mine by lifting on the left front edge it will not open but opens easily when I lift on the right front.
Don't know if the 14 and 21 are the same, but I place a little down pressure on the seat above the latch as I turn the key and it releases very easily. Good luck.
On my 2012 RT, I used a "wire wrap" to go thru the mechanism, and along side the cable, then draped the edge outside the closed seat. If I give the outside end a gentle tug, it unlatched my seat every time.
Yes I am lifting the right front, that's where the latch is.
I might have to try that
Thanks for all the replies. I'll keep trying them and see what works best for me.
If the latch is somewhat the same as the pre-2020 models the stud extending from the seat can be adjusted in both directions, i.e., front to back and side to side. Check that out and set it so the stud goes as freely as possible down into the latch. I was able to set mine on my 2014 RT so that it releases easily when I turn the key. I also keep it lubed.
2014 Copper RTS
Joe Meyer
I wired my seat latch with fishing leader wire from Walmart and strung it to the RH side grill just in case this problem occurs.....like last night....then I lubed it up again as I hadn't done so in a while.
