Results 1 to 24 of 24
    Mar 2021
    IL
    Default Installing new rear tire on my 2012 RT have a few questions
    A lot of the bolts are using a yellow locktite. Can I substitute red? The tire shop in my area is saying they can’t balance the rear tire. The motorcycle shop says it’s not necessary. Just interested in your opinions.
    2012 RT , Replaced with Bahrain wires Red
    Nov 2015
    Chardon, OH
    No. Substitute blue Loctite brand. That yellow stuff is a medium thread locker made by 3M. Blue Loctite is also medium.
    Doug
    ”Freedom is not a loophole”
    Active Member Partzman23's Avatar
    Jul 2020
    Sikeston ,Missouri
    Quote Originally Posted by LouW View Post
    If you are installing a good car tire on the rear it will not need to be balanced. Be sure to take off all the old wheel weights first.
    I installed a General Altimax tire on mine and did not need to be balanced. I have put over 8000 miles on this tire and have not had a problem.
    2017 RTL Asphalt Grey Metallic Chrome
    2017 RTL , Asphalt Grey Mettalic
    Sep 2016
    Chillicothe, Oh.
    Installed General Altimax without balancing. BLUE Loctite.
    2015 RT , Black
    Active Member nightcruiser's Avatar
    Feb 2019
    Indiana
    Balance with RIDE-ON and get puncture protection too.
    OK this caught my interest ..... " BLUE loctite " ....Why ???? Where ???? ...... thanks, Mike
    Sep 2020
    Middletown, NJ
    There were 2 questions from OP. The locktite answer was separate from the tire balance.
    2020 RT base , Chalk White
    Jul 2010
    Las Vegas, NV
    Red locktite requires heat to remove. Blue locktite is a perfect replacement for the OEM yellow.
    Any motorcycle shop can balance that rear wheel. Joe
    Joe Meyer
    Oct 2021
    Wichita, KS
    Tire beads.
    Peter Pan has struck again!
    Quote Originally Posted by RayBJ View Post
    Thanks .....that makes sense .......Mike
    Mar 2019
    NEBRASKA
    I use the general altimax rt 43 ( 18-22 lbs pressure) I take off the rotor for the tire guy and put the 5 bolts on with blue loctite. No balancing. Actually have it in the garage now just too tired....I did notice that my EBC semi sintered FA473V with only 4k on them are more than 1/2 worn....that's too quick as my OEM pads lasted til 16k in the rear...thoughts? 2012 RTL
    2012 RTL 14 RTS , Pearl White @ Pearl White
    You may not believe this, but I have never added any Lok-Tite to any bolt I have re-moved and then re-installed on any Spyder I have owned..... I have had every panel off dozens X's 5 over the past 12 years .... never lost a bolt or had any even loosen on there own .... I have always used Star washers on the Batt. terminals tho ..... good luck .... Mike
    INDIANA, USA
    Some people have all the luck. I usually don't get that much Luck. So I use the blue lock-tite for my own peace of mind. Different strokes for me. Thank You. .....
    ENJOY YOUR LIFE WITH A SPYDER
    Mar 2019
    NEBRASKA
    Mike (Blueknight911) how about a grommet-ever replace one of those?
    Quote Originally Posted by davev1pa View Post
    "grommet " ....????? need more info ..... Mike
    The rubber rings that the nubbins on the body panels slip into. If you push the panel in dry you might push the grommet out of the hole.
    Durham,Maine
    You trying to say you loctite them in?
    2012 RTL , Pearl
    Mar 2019
    NEBRASKA
    Lol lord no locktite on a grommet .......I was just curious on your never replaced/lost a bolt or nut comment...the grommets can loosen or fail or fallout with usage...I'm just messin with ya
    Durham,Maine
    That's why I have spares of everything handy!!!!
    2012 RTL , Pearl
    ......... thanks .... since I've never considered using " lok-tite " on a " grommet " ..... His post confused me ..... Mike
    Mar 2019
    NEBRASKA
    Sorry Mike(blueknight911)-I was kidding around..
    Houston
    There is no need to remove the rotor to change the tire.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Mar 2019
    NEBRASKA
    Ur right but after my first change the tire guy said it'd be nice to take the rotor off and I obliged on the next one...
    Sep 2021
    White Mountains, AZ
    Default Aside: no loctite on plastic
    I know that is a joke, but...
    A word of warning. Loctite (or generic) is DEADLY to ABS plastic. Don't let it smear out from the metal to metal onto the plastic. It makes it brittle. Technically, it leaches out the plasticizer, the polymer bonds break down and the panel will split with vibration.
    No brake fluid on the paint, no loctite on the plastic. Rules to live by.
