Results 1 to 6 of 6
    Oct 2021
    Virginia
    Default Can-Am-specific trailer stability control?
    I searched, but didn't find anything, so here goes:
    The description of the Freedom trailer states "Can-Am Spyder RT, ST, F3-T and F3 Limited Vehicle Stability Sytem adapts to the trailer."
    Does anyone know whether this is a Freedom trailer-only thing (for example, an electronic handshake with the Spyder that tells the VSS that a Can-Am trailer is attached), or does the VSS "adapt" to any attached trailer?
    Dec 2015
    Oakley Utah
    Quote Originally Posted by mneblett View Post
    Good question! I remember my dealer telling me the same thing about the RT-622 he was showing me.
    2014 RTL Platinum
    Feb 2012
    Spring City,Utah
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Very Active Member Trbayth's Avatar
    Jun 2014
    Schenevus NY
    Spyders with the 998 VTwin (all RS, ST, pre-2014 RT's) had a "trailer mode" that you had to manually set in the bike's settings. When trailer mode is turned on, it adjusted shift points, brake bias, and probably a few other things. I know this was for the SE's; not sure if the SM's had it as well.
    Spyder's with the 1330 Triple don't need trailer mode.
    Trb-- (Roger)
    2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
    2022 White Pearl F3T
    Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
    Spyder States Visited
    As Trbayth said it's the Spyder that has trailer mode ..... the trailer doesn't activate it ..... any trailer brand will work just fine ..... Mike
    Oct 2021
    Virginia
    Great -- thanks!
    I do patent work in the auto/motorcycle space, and based on my stability controls work, that was what I suspected -- but I'm not foolish enough to "assume." The knowledge here in the Collective is invaluable.
