Results 1 to 10 of 10
    Sep 2009
    La Valle, WI
    Default 28k trans filter change - Do I need to drain the engine oil first??
    On my 18 F3L. Do I need to drain the engine oil before changing it. Or is the oil level not that high. And if I do not need to change the oil, do you loose some oil when changing it.
    2018 F3 Limited , Oxford Blue
    Jul 2010
    Las Vegas, NV
    I always drain the oil first. Much less messy! It holds some oil, and even after draining, some drains out. You could raise the right side on a ramp, and just do the filter, but, I’ve not tried it. I did replace a clutch on a VROD, leaning the bike over. That was because the owner did not bring oil! It worked, but it really is easier to drain, replace the filters, then refill. If you try, post up! Joe
    Joe Meyer
    Yes, like cptjam states, drain the engine oil first.
    Aug 2019
    Stoughton, WI
    Dang Jerry .. You've been riding
    2022 RT Sea To Sky
    Northern Kalifornia
    I don't know your oil change sequence but why not wait until your next oil change to attack the trans filter. After all, it's just a chunk catcher. Mine was so clean I saved it and may use it again. Once you see it you'll know what I mean. JMHO but the cover should be made out of "see-through" material so you can visually check it. IE, don't change it until something gets caught in it. 28K change is just a suggestion. You could change it at 20k or 35K it doesn't really matter unless BURP left a set screw rolling around in there somewhere. Come to think of it, maybe that's why that filter is there.
    :roflblack
    Sep 2009
    La Valle, WI
    Yes I've had it less than 3 1/2 years. I ride between 8 and 9 k per season. I live in Wisconsin so it is put away for 4-5 months.
    I guess I will order the filter and do it with the end of season oil change.
    Sep 2009
    La Valle, WI
    Ok. I'm going to do my oil change and Trans filter this weekend. Do I need to remove the right driver floorboard to get the Trans filter off. My floorboards are in the position #3.
    Northern Kalifornia
    If the F3 frame is the same as the RT the bottom screw is hard to get at. Get a set of small bits and a small ratchet from HF and you can get into that screw easily to get it out. Otherwise, it's B*^%H!
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by JP58 View Post
    Duh Jerry
    2022 RT Sea To Sky
    Feb 2019
    Portland, Oregon
    The tranny filter on an F3 is out there for all the world to see. Easy Peasy to access.
