Results 1 to 8 of 8
    Dec 2012
    Murphy, NC
    Default How hard is it to replace an Upper Ball Joint?
    My upper ball joint needs replacing on my right front wheel. Has anyone done this themselves? Is it difficult? I have ordered the parts from Cheap Cycle Parts but am torn as to if I can do it myself or have the dealer do it.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    mine went as well last year, I had the dealer do it.
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Quote Originally Posted by JKMSPYDER View Post
    I have complete confidence in you John! Like they say. "How hard could it be? Just take off the old part and put the new one on! Easy Peasy!"
    May 2018
    millsboro,delaware
    Im guessing its set up the same as an RT so you will need a ball joint press with a small adapter which you may have to try to use a large socket bc they usually only have adapters for larger ball joints.If youve never done one youll probably scratch up the control arm pretty good so you might be better off getting the whole arm with the joint already in if they sell it that way.The other idea is take the arm off at the frame and remove the pinch bolt that holds the joint to the knuckle,then take the whole thing to your local auto garage or even better a machine shop,they have presses and could do that job in 10 minutes.
    : 2017 RTL ORBITAL BLUE
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    I did my lower ball joint easy you can borrow the tool from autozone
    Jul 2010
    Las Vegas, NV
    You can do it, John! I’ll have my phone on. Call if you get stuck! Joe
    Joe Meyer
    Dec 2012
    Murphy, NC
    Thanks everyone. As soon as the part arrives I will try installing it myself!
    2020 F3 Ltd
    Spyderpops Bumpskid
    Let us know how it goes! Better yet, video your work. Then we can all sit back and enjoy Monday Morning Quarterbacking your every move!
