Before I go to dealership (again) EBD/VSS/ABS fault, sometimes engine light P0900
Not sure if this is related or not, but I had a bad ground bolt underneath my seat, was loose and would not tighten
After several hours, we managed to get the old one out and put a new one in, hooked up battery (which is 2 years old) and bike starts up every time
Now I sometimes get the check engine light and then it disappears (when it did come up, i made sure to check the code P0900)
Now everything resets when i turn it off and within a minute, i get the 3 faults
EBD/VSS/ABS
Anyone know what would be causing all these issues and is the ground problem a result ?.
I know there isn't much time left in the driving season, not sure I wanna take it to the dealership this year or wait until next Spring.
Thanks for all the help/advice!
EBD/VSS/ABS
Why did you use a NEW bolt ??? .... I have Always put STAR washers on the batt terminals and grounds on my motorcycles ( they shake etc. ) and never had one loosen by itself .... just a thought ..... I suggest you remove the batt. connections, touch the leads together and wait about 10 min. .... then re-attach and see if anything changes !!!! ... I don't leave the key in the ignition, I put it on the dash surround ..... good luck .... Mike
From SpyderCodes app P0900: Clutch modulation solenoids shorted to ground or open circuit. Hopefully just bumped a connection loose. Everything resets after starting trip meters & such: double check battery for clean tight terminals & good solid charge maybe a load test.
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
I know when my battery went it started displaying similar icons
The old one would not tighten anymore with the nut, when we pulled it, the threads were bad at the end so it would not hold..
Update: I checked the terminals on the battery and the positive (red) was a tad loose, going to the hardware store to get star washers and taking the battery to be tested to make sure its still good
Ill let you all know what the result is... God, I hope its that simple
Well after i got my new battery yesterday (had to be charged overnight) , i put everything back in, made sure the terminals were tight and started it up
Same codes as before, but P0600 (ecm module) error was reported..
I think something electrical got loose etc as when we changed the ground bolt etc, maybe we bumped something
Anyway, put the cover on it for the year , and going to get it looked at next year or selling it
I must have got a lemon, as this bike has cost me $$$$ and within 2 years, I have put less than 2,000 miles on it
I think the previous owner rode it hard and fast and I'm paying the price for that..
