I am grateful for boards like this as they helped me enjoy my 2004 Goldwing that much more...thanks to all for your input and thanks in advance for any help...now on to 3 wheels.
Expecting a 2022 s2s in Feb 2022. Really prefer a dash center mount for my GPS...I have viewed what is available for the 2010 thru 2019 years....those mounted with 2 screws on the dash..have seen nothing for a 2020+.
I am hoping that there are some 2020+ owners out there and that you will share a center mount pic with wire routing and supplier for me to use.
I live in Pearland , Texas, just south of Houston. Thanks
I have mine mounted off the center of the bars using ram mounts. You can choose how high you want it with the link length.
The wiring goes thru the head stock under the right speaker grille and down forward to the GPS dummy plug behind the black panel. You'll probably have to remove the lower painted and right frunt panel too'
Here's the simplest way to mount: https://www.lamonstergarage.com/can-...all-lamonster/
BRP make a mount for the center of the handlebars. This set up is for my Garmin XT.
I will post pictures tomorrow. What I did was use a flat base ball mount and short ram arm and using 3M automotive dubbed back tape on the flat stick it to the center of the dash (on the top of the dash). I ran the power wires around the right side of the dash through the windshield arm opening to the power feed on the right side. This feed is powered with key on so you don't need the Spyder running.
I did this to both my 2020 RTL and my wife's 2021 Sea to Sky.
What's great is you never need to take your eyes off the road to see it.
Our 2014 RTL came with a GPS that was mounted in the middle of the handlebars and I always had to take my eyes off the road to look down at it. Especially with a full face helmet.
2021 Sea To Sky, 2020 RTL
Isn't it weird that in AMERICA our flag and our culture offend so many people...... but our benefits don't?
I used the bar clamp from Lamonster. Didn't use the ball part though. The powered mount from Garmin fits perfect on the bar clamp without the ball and is at the perfect angle for me. Simply route the power wire to the connection point inside the right cover. There are lots of videos showing this process. If you get the lights added to the floorboard the connector for power will already be used. I simply tied into this point also.
Can Am Spyder F3 Bar Clamp with 1" Ball (LG-1023) by Lamonster $69.95
1 × Lamonster F3 and 2020 RT Bar Clamp with 1" Ball
Zumo XT, Motorcycle Mount Bracket and Motorcycle Power Cable (LGA-010-12953-00/010-12953-03) $59.95
1 × Zumo XT, Motorcycle Mount Bracket and Motorcycle Power Cable
Thanks PW, I might steal that for my ‘21RT. The stock positioning for my XT on the centre bar bracket does indeed take your eyes off the road. Are there any licensing rights to be paid? If yes, my check’s in the mail
HeliBars Handlebars
Kenda Kanine rear.
