Results 1 to 11 of 11
    Jan 2020
    Orlando
    Default What are the best tires to use for a Can Am Spyder?
    What are the best tires to use for the Can Am Spyder RT Limited 2019 instead of Kendra Tires. I've seen a few different ones out there but would like to know anyone else experiencing better tires. Thanks
    Do a search and you will find enough information to cure insomnia.
    Durham,Maine
    Please do what he just said!!!!
    2012 RTL , Pearl
    Plug in "Vredenstein" for starters.
    Dec 2020
    Hartwell, Ga
    Also note the tire size's that are recommended, most are different from what's now on it.
    Active Member FlyBoy2121's Avatar
    Aug 2018
    Canada
    Quote Originally Posted by djflplayer View Post
    I had three kenda kanines installed, a good difference from kenda OEM.
    FlyBoy2121
    2014 RT ltd , original original Cognac
    INDIANA, USA
    Default Auto Tires for Spyder
    Check out the, "Vredenstein" or General Altima tires for the rear.
    Also check out your local dealer and see if they will install it
    Good Luck on Your Mission. ....
    ENJOY YOUR LIFE WITH A SPYDER
    Mar 2015
    forrest above Reno, Nv
    Quote Originally Posted by Little Blue View Post
    I have these tires on my and couldn't be happier.
    2014 RTS , Circuit Yellow
    , their up-dated model is the " Quatrac ".... it is the standard by which the other Auto tires are measured ..... jmho .... Mike
    Oct 2020
    Arizona
    Formoza x 2 and a General.
    Car tires! Beyond that there is no single clear cut answer. Do a search and read hundreds of posts here and you will realize it's your choice, and yours only. But you will pick up a lot of good info to help you decide which one you want to go with.
