Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
  1. #26
    Nov 2019
    Central Oregon
    Fine tuning
    Yeah, but what key? G? E flat? I'll get it sorted.
    2015 ST Limited; Givi E52 Top Case; Baja Ron anti-sway bar; Cal Sci wind screen; Vredestein Quatracs (front)
  2. #27
    Oct 2020
    Arizona
    Quote Originally Posted by Columbia View Post
    Take your pick!
  3. #28
    Fine tuning
    Quote Originally Posted by Snoking1127 View Post
    Take your pick!
    Oh come on!! You can't fool me, there's no picks there!! Those things is forks!
    Sorry but I just hadta! She >> made me do it!!
  4. #29
    Nov 2019
    Central Oregon
    Peter, you beat me to it! But our ride is made by CanAm, not Yamaha, so there are no forks.
  5. #30
    Nov 2019
    Central Oregon
    "A pun does not commonly justify a blow in return. But if a blow were given for such cause, and death ensued, the jury would be judges both of the facts and of the pun, and might, if the latter were of an aggravated character, return a verdict of justifiable homicide.” — Oliver Wendell Holmes
  6. #31
    Nov 2019
    Central Oregon
    I reworked this setup recently. Vibrations are mostly gone. The vibrations that remain aren't sufficient to either irritate or make seeing detail on the GPS difficult.
    I picked up a RAM mount, RAM-B-367U, which is designed to attach the ball to a handlebar, replacing the clamp bolts with the bolts RAM provides.
    I also picked up a LONG bolt, 10mm, if memory serves. My memory is a part time worker who, when it does show up for work, is quite lazy. That's to say "Don't trust me on the 10mm." I believe it was 3 inches, maybe a bit more. I also found in my washer collection a washer with a hole the size of the bolt diameter and the outside diameter of the washer sufficient to fit into the top of the RAM mount.
    The next thing I did was rough up the aluminum collar on the RAM mount. I used a file. You may use whatever you want to get away from smooth. When satisfied, clean what you just roughened. I used acetone. Alcohol of the rubbing variety would probably do well too. Then I mixed up some JB weld, not much. Applied a thin layer to that alu collar, trying to taper it a bit, wider at the top of the collar tapering to nothing at the bottom of collar. Let me emphasize: it don't take much! Let dry 24 hours.
    Remove the existing screw and rubber expansion nut.
    Tried fitting the alu mount in the hole. Too big. I dremeled the JB Weld, slowly and very gradually, testing frequently for fit. I wanted it to fig snugly, with as much of aluminum shaft in the hole as possible. BUT: keep in mind that too much in the hole means the ball might be too close to the dash to be able to fit the RAM arm.
    Look at things for a few minutes. You'll see what's right. "Right" equals what will work best for you.
    Eventually I got it sanded to the right fit. Then:
    Thread the 10mm bolt down through the washer in the RAM mount and into the expansion nut. Insert into dash hole.
    Tighten. I tightened with care, lest I crack the dash hole. Got it quite tight without cracking. "Quite tight" equals a fit that left the GPS jiggling a bit but not excessively nor such that seeing and following the GPS was difficult. Is it rock solid? No. But it's where I can easily see it and it's "small rock" solid, with thanks to Monty Python.
    The new mount works a treat. I have a locking RAM bolt holding the arm tight and not easily removed. (The arm is RAM-B-201U-A, which I had in my RAM collection already. You could try a longer arm, but I'd wager vibrations will increase with length)
    I've lost bike stuff to thieves in the past. So I remove the Garmin when I leave the bike unattended. There are lockable mounts. Not worth the expense or hassle for me to go that route. I DO have a small, very small, keyed padlock that I can fasten around the Garmin's mount-eject-button which keeps the button from being depressed and the GPS mostly safe. Of course, if someone wants it badly enough, they'll just break the mount to score the GPS.
    I'm sure there are ways to improve what I've done. This works well for what I need. Improve away to your heart's content.
