What's the little battery indicator when phone or MP3 connected?
ive noticed a small battery icon on my display. bottom when phone or mp3 player is connected,, i dont see any such icon in my manual ?
2020 F3 limited, liquid titanium
grip puppies
Bajaron sway bar
lamonster belt dampener
battery tender
19 in freedom tinted windshield
matte black daytona frunk wrap
Quadtrac 165/60's
Ozzie Ozzie Ozzie
I believe it's cos you've got an Aux device connected to the Spyder via the USB charging port, so the indicator is showing you that Aux device's battery condition.
2013 RT Ltd Pearl White
Ryde More, Worry Less!
Sounds like the red battery (Charge) icon. Is it only illuminated when your phone or Mp3 player is connected? Hmmmmm…… check to see that while engine is running, that the charging voltage is 14.5 volts.
If it is 14.5….. you’ve got a gremlin hiding somewhere.
If it is not 14.5+ or - 1volt…. I’m thinking a charging issue.
Reason: Removed spurious 'Â's...
The one on the lower icon bar across the bottom? Page 33.
Doug
”Freedom is not a loophole”
It's showing the charge level of your device.
