Results 1 to 20 of 20
    Active Member michrick's Avatar
    May 2015
    Liverpool, NY
    Default 2016 RT rear fender repair?
    Hi all has anyone ever repaired their rear fender. I noticed mine is cracked and the only thing I can think of is I just installed the batwing mud flap on my BRP hitch. I think the fender might have hit it but I’m not sure. Anywho I want to fix the crack and I’m reaching out to see if anyone has done this project before. Thanks much, Michrick
    Hers 2014 ST
    His 2016 RT Limited
    2016 RT Limited , White
    We had a small crack in the fender on the 2014 RT. I fixed it with black duct tape. Traded it off that way with disclosure, no issues.
    Ouch! I had a friend whose hitch mud flap hit it on a rough railroad track crossing. His crack was bad enough that he replaced the fender, PN 708302277, $184.99 from Cheap Cycle Parts. Don't know if one could repair with a separate piece of plastic from inside the fender without having it look like a shade tree job unless it was minor like ARtraveler's was.
    Active Member Bob L's Avatar
    Oct 2014
    Massachusetts
    I had the same issue, so I used a Dremel tool and cut down the rear fender above where it cracked.
    Bob L.
    Worcester County Massachusetts
    www.rk-mass2.org
    Active Member FlyBoy2121's Avatar
    Aug 2018
    Canada
    Quote Originally Posted by michrick View Post
    I Michrick !
    I repaired a crack on the cover that was removed for the oil change, I made a piece of ABS the same shape where the crack is and with epoxy for ABS I glued, and everything is fine solid.
    FlyBoy2121
    2014 RT ltd , original original Cognac
    May 2015
    Liverpool, NY
    Thanks all for some advice. This will be a winter project so I can pull it off. If it last that long. I may look into a color match rear bumper from Can Am Spyder Accessories?
    Hers 2014 ST
    His 2016 RT Limited
    Sep 2014
    USA
    I had that piece of plastic on the top of the hitch and yes it does hit the fender. So that got removed replaced the fender and installed a mud flap.
    May 2015
    Liverpool, NY
    Thanks much trikermutha mine is being removed as well, I guess I learned the hard way
    Hers 2014 ST
    His 2016 RT Limited
    Sep 2021
    White Mountains, AZ
    Can you clamp it so the the crack is forced together?
    If you can, simply clean out the surfaces of the crack, wet them with acetone, then apply ABS cement (available in the plumbing dept of any hardware store) to the crack and clamp it. Give it at least a day to set, remove the clamps, and carefully sand it smooth.
    Sep 2014
    USA
    It was fine for awhile but think the shock was going south and ended up upgrading the shock but still replaced the fender since I damaged it more that once.
    May 2015
    Liverpool, NY
    Yeah I will replace mine over the NY winter but for now I will try some tape on the rear inside of bumper. When I saw that crack I was PO’d but you live and learn I guess. The hard way.
    Hers 2014 ST
    His 2016 RT Limited
    Sep 2014
    USA
    Yeah I share your feelings.. Good luck! Hope you can still get one I been seeing some parts are starting to be discontinued.
    May 2015
    Liverpool, NY
    Yes Thanks I’m searching now to find the best price on that rear fender. Looks to be about $185 I use to have a Victory and remember how they started to discontinue items so I’m going to get one now. I’ve also reached out to Pierre on the color match rear bumper. It looks like there’s a core charge and you need to send him yours but being broke I’m sure that’s not possible.
    Thanks again
    Hers 2014 ST
    His 2016 RT Limited
    Sep 2014
    USA
    Just seen one on ebay for 295 shipped. and its used.. That one is way over priced.
    Found another and free shipping. But says for newer model. Not sure what the difference maybe??
    https://www.ebay.com/itm/Spyder-2017...-/202508026533
    Heres a cheaper one
    https://www.ebay.com/itm/19391506688...2921e1c84894f0
    Dec 2020
    Hartwell, Ga
    Heres a cheaper one
    And another if it will fit.
    https://www.walmart.com/ip/Spyder-Ne...d&gclsrc=3p.ds
    Sep 2014
    USA
    Same place that sells it as the second link I posted and was cheaper.
    May 2015
    Liverpool, NY
    Thanks much
    Hers 2014 ST
    His 2016 RT Limited
    May 2015
    Liverpool, NY
    Might try some ABS repair stuff with mesh or try to weld it as a test project, all from the back side so it’s not so noticeable. Worse case I buy a new one like I plan to
    Hers 2014 ST
    His 2016 RT Limited
    Sep 2014
    USA
    Its not to bad to remove the fender. I thought about repairing mine but dont have the time or patience to find out it works or looks like crap..
    May 2015
    Liverpool, NY
    Yeah I’m more curious than anything so give it a try I’m researching what brand is best.
    Hers 2014 ST
    His 2016 RT Limited
