Results 1 to 6 of 6
    Nov 2018
    Des Moines IA
    Default Sticky suggestion to Admin
    With the search feature on this forum being less than desirable, I would like to request a Sticky for tires that work by model on the Spyder. It sure would save a lot of searching posts and provide the information in a single spot.
    Tires that fit are what seems to be in short supply.
    2018 Spyder ST Limited , Asphalt Gray
    Northern Kalifornia
    How short would that be? I just ordered a tire from amazon. It'll be here next week. If something is not being readily manufactured or not in stock then yea, you'll have a long wait. There's more than just one brand of tire that will perform well on a spyder. I like your idea of creating a Sticky for tires, and oil, and tire pressure, and belt tension, and fuel mileage. It would sure reduce a lot of clutter and redundancy on the What's New page. JMOP
    Mar 2013
    Maumelle, AR
    The question should be is, "Who will change a non-Kenda tire?" Many dealerships will not. It would be nice to know the dealers and independent shops across the country who will.
    2020 RT Limited , Chalk
    Server Admin AnthonyG's Avatar
    mi
    Once you make the list, it can be stickied.
    2018 F3 , Red
    Nov 2018
    Des Moines IA
    I am a noobie! I was hoping some of the more seasoned guys might step up.
    mi
    Quote Originally Posted by lstayner View Post
    Did you use any boolean search options to be more specific in your searching on the forum?
    Here is an example site to read up on boolean searching which is the standard.
    https://care.icims.com/s/article/Int...Boolean-Search
    Did you make a new thread & ask the seasoned riders to help you compile all that data to create a list?
    2018 F3 , Red
