How often do you change the oil in your Spyder?
I just passed 3,000 and had the initial service done. Is 3,000 overly conservative going forward, or realistic for needing an oil change?
2021 Spyder RT
Retired U.S. Army
Life Member, NRA
manual recommends 9,300 miles now or 1 year
I get the oil changed every year.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
I change it every 5,000 miles. That usually is about twice a year.
Full synthetic might get better mileage, but least one a yr on oil. Brake fluid 2yr max
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
Deanna
X 2 for me also. The miles that I put on do NOT exceed the recommendation.
Tri-Axis Chrome Handlebars
Sena SM10 BT Dongle
Double USB Port/Volt meter
LaMonster Magic Mirrors
BajaRon Swaybar
HALO Skid Plate
Shorty Antenna
LaMonster Cat Delete
Akrapovic Muffler
FOBO2 TPMS
Rear Trunk Rack
Bruce Erickson
Chilliwack, BC
Canada
2014 RTS-SE6 - Cognac
The maintenance schedule, pg 113 of your operator's guide, says every 9,300 miles or once/year, whichever comes first. IME, since I ride year round there is no reason to change it at less than 9,300 miles.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
Every 9,000 miles, give or take a few one way or the other.
BRP states every 9300 miles after the first one at 3000. I do 9000 as it's easier to remember even numbers - as in 12,000, 21,000, 30,000 compared to 12,300, 21,600, 30,900.
150,000 combined miles on 1330 motors without any oil related issues.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
I change my oil every November, just before winter storage. I usually have 5-7K on the oil. I'll be ordering my BR oil filter kit next week
2022 RT Sea To Sky
Changed at 3000, 7000 (pre-trip), & 14000 (pre-trip). Always full synth. I log lots of miles per year so I've never gone a year without at least 2 changes. So far, no oil loss between changes.
Better to change Oil before or after it has been in storage for the winter?
If you have to lay up for a number of months, add stabil or seaform to your gas tank before run to warm up the oil and then do the oil before storing.
I have the oil changed when the spyder is in storage/hibernation. I use full synthetic for wet clutch systems.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
Before. Dump out the acidic and crudded up oil before storage.
2022 RT Sea To Sky
How long does a spyder have to be parked before it is considered to be in a storage/hibernation condition? When that time is met, how long does it take before that cruddy acidic laden oil can damage the engine? If the oil had been changed say at 3k,4k, or 6k miles prior to being parked, would that be considered as badly contaminated oil? How about just draining it all out and having it analyzed and if still useable, put it back in after storage?
SpyderLovers Ambassador
OIL Change and ENGINE OIL SAMPLE
I change my Engine Oil as per BRP (9300 miles or once a year). I also pull an Engine Oil Sample and have it analyzed. The Blackstone Labs results have come back with Excellent feed back. As a Retired Heavy Equipment Technician with 40+ years, I Know the Value of doing an oil sample.
It's your Spyder, so you do as you please. ...........
ENJOY YOUR LIFE WITH A SPYDER
My Spyder ..... 'Little Blue-Boy'
