Results 1 to 8 of 8
    Active Member Baron14y's Avatar
    May 2019
    Palm Bay, Florida
    Smile Baldwin Iron Works Highway Pegs for RT
    New, never installed. Still in packaging. $100.00 inc shipping.
    Last edited by Peter Aawen; 09-22-2021 at 05:48 PM. Reason: Just checking Thanks/Likes... %-/
    Sep 2017
    INDIANA, USA
    Default Hi Way Pegs
    What color are the parts? They look black. Are they made in the USA?
    ENJOY YOUR LIFE WITH A SPYDER
    May 2019
    Palm Bay, Florida
    Quote Originally Posted by Little Blue View Post
    They are black and made in Missouri.
    Sep 2017
    INDIANA, USA
    Default Hi way Pegs
    Just curious, Why you got them and now you are selling them. How Do They mount on the Spyder RT? Do you need to drill holes? I will not drill holes in my Spyder RTL. Sorry just me.
    Nov 2016
    Upstate NY
    Those pegs require drilling the floorboards under the rubber mat. The instructions or template is wrong on all those pegs. I know because a friend installed them and the template is wrong. He redrilled and mounted them correctly. Check the reviews and pictures on amazon and you will see them mounted incorrectly. (Weird angle). Very strong and high quality. I modified a set for my 2021 RT
    2021 Sea to Sky RT , Highland green
    May 2019
    Palm Bay, Florida
    Just never got around to putting them on. As far as the template is concerned, although never used, mine look correct. Some have been known to use them on the wrong side thereby having the holes incorrect. Worse case, use the pegs themselves to mark the locations of the holes. Both the base and the pegs are adjustable to set to your liking.
    Mar 2019
    NEBRASKA
    I have some on a 14 RT and they install easy no problem....I did drill a couple holes in the floorboards..no biggie. These only fit on factory floorboards so 2013-19 RTs. Not on 20 and up. He also has these for the F3. About $120. They get the job done but there are prettier ones out there. If your RT has pegs they won't work.
    2012 RTL 14 RTS , Pearl White @ Pearl White
    Dec 2013
    Have they sold yet Baron?
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
