Results 1 to 11 of 11
    Jan 2021
    WA
    Default Spyder F3 Oil Filter Cap
    So, I really screwed up and rounded out the nut on the oil filter cap. See the photoSpyder Cap.jpg
    This was before I had gotten the 36mm 6-nut socket. I bought the socket and completed the rounding of the top. Any ideas on how to get it off? I tried the plastic oil filter strap and the strap keeps sliding. Any ideas would be appreciated.
    Grab it and twist with a large pair of Channellock pliers; might not hurt to use the kind in this link, https://www.homedepot.com/p/Channell...-422/301938565. The cap is supposed to be tightened only to 18 lbft, +/- 2 lbft.
    Active Member MrMagicFingers's Avatar
    Apr 2020
    Dartmouth, Nova Scotia, Canada
    Hey...
    Not familiar with that setup but it looks like there is a metal band around the body that perhaps mounts it to the bike/frame/engine.
    If that is really tight, it may constrict the plastic body and prevent the top from unscrewing. Try loosening that band if you can and then trying again to remove the cap.
    You could also try to file down the plastic cap sides to make a smaller "Nut" to a smaller socket size or a smoother surface for an adjustable wrench on it. Plastic should never get that tight.
    Tim
    Current - 2010 Spyder RTS
    1) Experience is something you don't get until after you need it.
    2) A closed mouth gathers no foot.
    3) IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU HAVE TIME TO DO IT OVER??
    ___
    Horsepower is an illusory mathematical equation; Torque is REAL, and is the source of all good things in the world.
    The problem is not the problem. The problem is your attitude about the problem. Do you understand?
    Please check out my pics!!
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    Pliers would do the trick, Loosen the metal band als would do the trick, if that all fails, drill a small hole, so that eventual vacuum can relase, be carefull for plastic bits, that may fall in the filter....
    or try gently putting a small screwdriver, between cap, and cannister, to release vacuum, like opening a glass jar...
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    Quote Originally Posted by Piratezz View Post
    There is no vacuum holding it on. It is a vented system. It is held on by over-tightened plastic-to-plastic threads. Order a new cap and screw it off with slip-joint pliers after removing enough tupperware to get a good grip on it. But please, make sure you turn it counter-clockwise (anti-clockwise for those with British language influence). I doubt the metal band is effecting it. I fear removing the band would permit twisting the housing enough to break it off.
    1976 RD400c
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Channel lock or small pipe wrench. First I’ve seen of this. Plastic oil filter housing ? Sheesh !
    it was fun while it lasted.
    Quote Originally Posted by coz View Post
    ...First I’ve seen of this. Plastic oil filter housing ? Sheesh !
    Works like a champ if one uses the proper tool.
    Active Member T.P.'s Avatar
    APPLE VALLEY, MN
    WOW!! That's FUBAR!!
    T.P.
    Mar 2013
    Marion, Arkansas
    Quote Originally Posted by Spydermech View Post
    People smarten up. there is always a correct tool to do the job at hand. This is what happens when you don't. Of course if you got more money than you know what to do with, keep doing stupid things.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Apr 2020
    Spydermech...
    Disregard some of the harsher posts... I for one would like to know how you made out. I am truly interested in finding out how you resolved it. Lots of things get "stuck" in life and your solution my help others.
    Please let us know!
    Tim
    ___
    Mar 2015
    forrest above Reno, Nv
    And plastic gear for the water pump also. Don't ask me how I know-----------
    2014 RTS , Circuit Yellow
