Results 1 to 12 of 12
    Sep 2021
    Tennessee
    Default Comments & suggestions on Front Tires?
    New owner of 2017 Spyder RT Limited with original tires. Have read different posts regarding replacement of front tires. Intrigued by the thought of tire(s) with a stiffer sidewall to help reduce body roll while cornering. Comments and suggestions appreciated. Thanks!
    Last edited by Peter Aawen; 09-16-2021 at 05:13 AM. Reason: Removed Prefix - this is a 'What should I use?' question not a 'How To: DIY' guide. ;-)
    Sep 2017
    INDIANA, USA
    Default New Member
    First off, Welcome to the Spyder Forum.
    Check out the posts on this Forum.
    Currently there are 2 or 3 up running. Check them out.
    Front tires are easy to replace. If you can remove your wheels/tires from your Spyder.
    You will save a ton of money.
    Good Luck .....
    ENJOY YOUR LIFE WITH A SPYDER
    SoFlo
    Federal Formoza high performance tires on the front of our Spyder RT, and have installed them for others with never a complaint.
    Idaho
    Do a search for front tires here in the forum. It'll take you longer to read all the info and comments than it would take you to ride to New York!!!!!
    2014 Copper RTS
    Sep 2020
    Middletown, NJ
    If BODY ROLL in corners is what you're trying to fix, you'll be better off getting a BajaRon sway bar or replacement shocks. Auto tires will add traction and give a better 'feel' for the road.
    2020 RT base , Chalk White
    Default spyder tires
    Quote Originally Posted by Fredly View Post
    & .... currently the New model Vredestein tire ( the Quatrac ) is the highest rated tire available .... you can get them now ( even in the current tire shortage ) from tirerack.com ..... 165/60-15 .... if you order on-line or by phone check the " decline veh. info box " ... these are AUTO tires and they might not sell them to you .... for LEGAL reasons ..... even tho the Spyder has AUTO type " J " wheels which match Auto tire " bead " shape ... I could type for Hours explaining this, but it has already been posted here for years ..... good luck .... Mike
    Sep 2017
    Durham,Maine
    Do yourself a favor if you have a rainy Saturday morning and get a cup of coffee and type in the search engine, car tires, and get ready to drink a pot of coffee and oh yes have a couple aspirin ready, because you will get a headache for sure!!! You have to do it at least once!!! The Bluenight is worth listening to in my book, he has this subject hands down, trust me!!!
    2012 RTL , Pearl
    Well thank you for the compliment ...... also Peter Aawen has excellent info ( if you like very long explanations ) but they are worth reading ...... Mike
    Active Member thereverend's Avatar
    West Monroe, LA
    Default thanks Mike
    Thanks Mike, just ordered 2 of the Vredsteins 165/60/R15's going on my 2015 RT
    Active Member Partzman23's Avatar
    Jul 2020
    Sikeston ,Missouri
    Fredly, I Sent PM
    2017 RTL Asphalt Grey Metallic Chrome
    2017 RTL , Asphalt Grey Mettalic
    Jan 2019
    Hunter Valley NSW Australia
    I have a '17 RTL and this is my write up of NanKangs on it https://www.spyderlovers.com/forums/showthread.php?124948-Nankang-XR611-Rear-225-50R15-fitted-to-RTL
    2017 RTL
    2017 RTL , White
    Nov 2018
    Claremore, Ok.
    Federal Formoza AZ01 @ 17 psi for fronts, Kumho Ecsta AST KU25 All-season tire 225/50R15 91H @ 18 psi, If "Management" is riding along I up psi to 20.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
