Results 1 to 8 of 8
Thread: I screwed up.
    Milton Nh
    Default I screwed up.
    A few weeks ago I had to jump start my Rt, my first mistake is I left my key on. The next mistake I made my battery pack was dead. Now for the biggie I hooked up the jumper cables backwards.
    So now here comes the problems I had to have the dash replaced because it burnt out the led screen. Now I have it back the low gas light stays on witch the gas gauge say full and I know IT is because I filled it.
    Problem 2 is when I adjust the air suspension the manual screen comes up but I can hear the compressor and also feel the seat raise up.
    Trying to solve these problems.
    SoFlo
    Sounds about the same results sometimes when an aircraft has lightning strike. As Forrest Gump says “you never know what you’ll get”.
    Aug 2008
    MA & NH
    Good luck, sorry to hear.
    Dec 2015
    Oakley Utah
    I don't think you have provided enough information for anyone to really help diagnose the problem.
    Why not take it back to whoever replaced the dash (whatever that means ...)?
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Quote Originally Posted by steviep View Post
    A few weeks ago I had to jump start my Rt, my first mistake is I left my key on. The next mistake I made my battery pack was dead. Now for the biggie I hooked up the jumper cables backwards......
    Hooking up your battery to a dead charging source shouldn't hurt anything.....
    2014 RTL Platinum
    SoFlo
    Connecting the jumper cables incorrectly, likely to start it since his battery was dead, he most likely turned on the key with power reversed and the electronics objected and told him so.
    There’s so much durability with old non computer controlled vehicles that had breaker points, but then again, you needed to know how to work on carbs, distributers, and more.
    Milton Nh
    So when I hooked it up backwards it was to a good battery,actually my battery pack that was also dead has a sensor that disconnects if you hook it up reverse. I do plan on having the dealer fix these problems just right now I'm about 150 miles away so it will wait until I get home.
    I'm just trying to figure out a few things on my own. Such as the air ride like how to test the level control. If I could find a good wiring diagram it would be nice.
    Active Member ris's Avatar
    Jun 2016
    N.H.
    I had to have the dash replaced on my 2015 RTSE6.
    After replacing the dealer has to go thru a few steps to reset the air ride.
