extension on back of gear shift button
I watched a video which showed a Spyder with what looked like an extended piece, like a short tube, on the back of the gear shift button, which would make downshifting less awkward that having to reach behind the stock button to push it forward. Does anyone know where I could order such a device?
2021 Spyder RT
2023 Royal Enfield Hunter 350
Retired U.S. Army
Life Member, NRA
I designed and sold a leather covered extension that was ergonomically shaped and would be attached to the paddle on SE spyders ..... I have pics in one of my Albums ..... Mike
Unless one is missing a digit or two, what is awkward about upshifting with the left thumb that hangs down from the back side of the left grip and downshifting with the left index finger that hangs down the front side of the left grip. What am I missing even though I have all ten digits?
The reason I created my " extension " ( which is actually a raised pad) was for folks with short THUMB .... I didn't consider using it for Down-shifting only Up-shifting .... I have small hands and it helped me .... It has helped many others ..... Mike
I can reach the back of the “+” button for downshifting, but it is not as comfortable as it would be if the button extended further to the back, I.e., thicker or with an extension. Paddle shifters, with the downshift paddle set up for the opposite hand would have been even better.
2021 Spyder RT
Retired U.S. Army
Life Member, NRA
IRT Mike and vito, I guess I've just lived with my digits, which are rather long, for so many years it prompted my comment about awkward. My apologies, absolutely no insult intended.
Shifting issues
Unless your SE shifting mechanism is radically different than the 10 thru 18 RT's which Don't have Buttons ( they have TWO separate Levers ) I think you are missing ( ie broke off ) the downshift LEVER ../.. if you can post a pic it would be very helpful. ......thanks ..Mike
I am missing most of my left hand index finger and thinking about making an extension for the down shift although I don't use it very much. (don't argue with a horse, a rope and a trailer divider. I lost)
It is comfortable to me but my wife rides the Spyder mostly & says she wishes the levers were longer
2020 Can-Am Spyder RT
2018 Honda Goldwing DCT
I was going to post a question and then saw this thread. My question was can the bar controls be twisted? I've had bikes that could be adjusted and others that had a locator pin. One could cut the pin off if he was of the determined type?
I do have a partially amputated left thumb. Table saws make quick work of flesh and bones. I'm able to shift but do need to rotate my wrist down more then I would like.
Mike, do you still have the extension pads you spoke about? I would be interested.
Thanks for the explanation. It sure clears things up and makes it perfectly understandable why you're looking for a solution. Maybe I can think one up!
BTW, about the user name change you mentioned above. Contact an admin via the link at the bottom of the page. They can change all your posts to the user name you want.
