Tach quit - 2020 RT-L
This afternoon my tach quit - just showing a 0, and the needle isn't moving either.
Anything I should be looking at ? Any suggestions ? Really don't want the 2 hour one way trip to my Dealer if it might be just a fuse. THX.
I Bluewater
There are a lot of electronics on a spyder, I would disconnect the negative from the battery for a good 5 minutes to reset the electronic
FlyBoy2121
I agree with FlyBoy's suggestion. A year or so after purchasing my Spyder new from a dealership I stopped to refuel and after turning on and off the ignition switch when I failed to set the parking brake I filled the tank, started the bike and rode off. I glanced down at the gauges and noticed the digital and analog tachs were off by 500-600 RPM; don't remember which was reading higher than the other. Rode for an hour or so and stopped for some liquid refreshment at which time I turned off the ignition key, removed it and walked into the store for my purchase. After a 15 min or so break I jumped on the bike, fired it up and the tachs were reading identically. Problem has never again happened. Touch wood.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
Thanks Flyboy2121 and JayBros for the suggestions. Just tried it now, and the numbers and needle are back !! Damn touchy electronics.
I'll remember about disconnecting the battery tho - I have to do that with my modem when my internet goes down. THX again.
