Results 1 to 25 of 51
Hybrid View
    Member Chappy KC's Avatar
    Oct 2017
    Delaware, Ohio
    Default Need to replace Camshaft Position Sensor, on back-order. Can I Repair?
    I would like to replace mine but it seems they are on back order until October 2021. I'm just wondering if it's possible to repair the one I have? There is some oil on it. Any thoughts?
    2017 RT-S. Bone Stock!
    Quote Originally Posted by Chappy KC View Post
    Have you checked with all the after-market vendors ... like cheapcycleparts etc... ....Mike
    Oct 2017
    Delaware, Ohio
    BlueKnight...Yes. CheapCycleParts say it may be here 14 Oct. Shops in my area say the same. However it does appear that many CanAm ORV's use the same item.
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    It doesn't surprise me that they are out of stock. It seems that most that are in 16/17 bikes all failed at about the same time. I personally know of 11 bikes that failed within months of each other
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Jul 2021
    PA
    How many miles on these bikes when they fail?
    Mar 2008
    Hesston, PA
    My 2014 RTS has close to 40,000 miles, still on the the original...But I do carry a NEW spare...larryd
    Mar 2015
    forrest above Reno, Nv
    Where on the is this sensor located??? I'll assume ( I hate to do that ) that it's on the cylinder head on the left side.
    2014 RTS , Circuit Yellow
    Oct 2017
    Delaware, Ohio
    Quote Originally Posted by msawdust View Post
    msawdust...Generally by 28k miles. Mine has just about 23k.
    Well NOW I'm nervous .... I have 66,000 miles and mines still; OK .... .....Mike
    SoFlo
    Could be wrong, but like DESS they fixed what was not broken. Typically the 2015 but more so 16 & 17 have had issues.
    Active Member malibu_dan's Avatar
    Oct 2011
    Hotlanta
    Call a dealer you trust. If they don't have the part in inventory, ask them to pull up the list of dealerships that have the part in stock. I drove an hour and picked one up thanks to my usual dealer doing the part search for me.
    According to my service manual other than having a multimeter to test the camshaft position sensor there is not much one can do to repair it. It's a test and replace if out of spec item.
    Oct 2017
    Delaware, Ohio
    Thanks JayBros for that info. Figured as much.
    It's actually on the right side just a little ahead and inboard of the oil filter canister. See the picture below.
    Mar 2015
    Thank you sir. I just may order one to keep on hand.
    Active Member T.P.'s Avatar
    APPLE VALLEY, MN
    Here we go!! The part Number 420664049 is the 4th part # for this cam sensor. most BRP units have it, From the Spyder's to OHV's and SEA DOO'S and SKI DOO'S
    My dealer has 2 special ordered for me but pointed me to one in the middle of Wisconsin, SPOKEN FOR, so I'm # 3 on the list for that one.
    The sensor fault code is PO340 and your Spyder will go into Limp mode. I rode mine 400+ miles home at regular speeds last year
    T.P.
    INDIANA, USA
    Camshaft Position Sensor........
    So have you received the parts?
    Did you install it?
    How many miles do you have on your Spyder?
    Always trying to stay ahead of the problems.
    Thank You for your Inputs. ......
    ENJOY YOUR LIFE WITH A SPYDER
    SoFlo
    Was reading on the FB group, apparently there is now aftermarket versions of these sensors, but oem is superior.
    Have not dealt with this myself, merely sharing information.
    May 2018
    millsboro,delaware
    I got 20k out of mine on a 17rtl.Drove 500 miles home bc no dealer nearby had one.I got mine from cheapcycleparts.com.
    : 2017 RTL ORBITAL BLUE
    INDIANA, USA
    Quote Originally Posted by spyder01 View Post
    Who made the repairs?
    INDIANA, USA
    Default Parts are still Being BO
    So did you make the necessary repairs?
    Or was the issue repaired by the Dealer? ......
    APPLE VALLEY, MN
    I put one in for a friend yesterday, It's a tight fit to get at it. 8mm open end-box end wrench, had to use both ends.
    T.P.
    12-2-21 UPDATE, Just located 1 sensor in Canada that will be the spare.
    Going to be a trick to get it into the US
    Canadian Can Am dealers cant ship into the US
    WSM 004-520 Is the after market sensor that will work, But you will have to install yourself.
    T.P.
    INDIANA, USA
    Default Any news?
    Just curious if there are any updates about the 'Camshaft Sensor'.
    Anyone have more information about the sensor's?
    Thanks in advance. .....
    Mar 2008
    Hesston, PA
    Quote Originally Posted by Little Blue View Post
    Maybe PMK could offer some more information on the aftermarket alternative???
    SoFlo
    Quote Originally Posted by larryd View Post
    I have no specifics on what others have used. Suggest those needing replacements research for more info on FB.
    Seems these failures are becoming more common on certain year machines.
