Results 1 to 5 of 5
    Jul 2021
    Kentucky
    Default 2013 RT Spyder with P1036 code - any info/help?
    I hope I can find some info. I have a 2013 Spyder RT Limited. While on a trip recently the check engine light came on. Checked the code and it is a p1036. I was thinking it is a code for the oxygen sensor. I have recently changed the vacuum hoses, oxy sensor(both), plugs and wires, and cleaned out the catalytic converter, and new exhaust seals, and purge bypass. Ran great. Drove about 400 miles and it came on. It still ran fine. Drove it home about another 200 miles. Please help.
    Dec 2013
    P1036 - Module: ECM
    Oxygen sensor heater 2 upstream cat.
    Signal error.
    Damaged 02 sensor damaged circuit wires.
    Damaged connector or damaged ECM pins.
    Check fuse.
    Disconnect HO2S 2.
    Measure voltage between harness connector HO2S 2-1 & Ground
    (expected value = 11 to 13 V dc).
    Circuit wires may have become heated, pinched, or broken. All pertinent wires & connectors should be carefully inspected for damage.
    Good Luck!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Jul 2021
    Kentucky
    P1036 - Module: ECM
    Signal error.
    Check fuse.
    Disconnect HO2S 2.
    Good Luck!
    Thanks for the info but I’m not sure how to check the sensor.
    Mar 2013
    Marion, Arkansas
    You need a DVM or some other device to measure DCV, and Peter explained what the voltage should be. Good luck.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Nov 2015
    Chardon, OH
    Hey Chief. So, you replaced both O2 sensors and 400 miles later you now have a code for the heater circuit failure for the rear sensor. On your machine, that fuse feeds a number of other things and the machine wouldn't even run, so that's probably not it. Refer to your operator's manual. You'll just need to go back and re-visit everything you touched when you replaced that sensor,...harness, plug, etc. Or maybe it's just a bad sensor.
    Curiosity killed the cat - just wondering why you replaced both sensors in the first place and if you used genuine BRP OEM parts?
    Doug
    ”Freedom is not a loophole”
Tags for this Thread
