Results 1 to 8 of 8
    Aug 2021
    Texas
    Default Just fitted LED’s. Awesome!
    Just fitted them. Had to take the headlights out but its only 3 screws.
    Easy and look awsome!!
    Jul 2021
    PA
    Which kind did you get and can you post a link?
    Jun 2015
    Ritzville, Wa
    I have to agree. I think the very first upgrade a Ryker owner should do is LED headlights. And like you I would suggest removing the headlight assembly. Like you said, it's only three screws and makes installation so much easier.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Aug 2021
    Arizona
    I am apparently missing something, but I have led lights similar to those referred. How do you get the rubber grommet over the flange or the fan cover? I have been attempting to stretch the thing but not much luck even with heat.
    Thank you
    George
    Arizona
    Jun 2021
    Mass, USA
    The led bulbs on my Ryker are better than the lights I got on my 2017 F150.
    Active Member DickB's Avatar
    Jun 2021
    FL
    Quote Originally Posted by geosar View Post
    Thank you
    George
    Arizona
    I don't have the same bulbs, but I had to cut the grommets to fit. The previous owner tried to stretch the rubber over the heat sinks, totally wrong.
    Sep 2021
    Washington
    Just did this yesterday! No need to remove headlights though... Just took a little time and patience.
