2011 RT fender lights - what amps would strip LED's draw??
Hi all. I am wanting to put the strip LED light to the fender but want to route via a separate accessory fuse block. What I am trying to ascertain is the amperage or watt being drawn so I can place a fuse on the block.
I have searched online in all the places I know and nothing comes up - just how to wire or using the given plug n play scenario.
Thanks in advance
2011 RT , Manuctaured my own for aux lights Pearl white
All my electrical accessories are connected to a fuse block that is fed via a relay that is on only when the ignition is on.
Here's where I got it....
https://www.banggood.com/IMars-10-Wa...N&rmmds=search
Thanks this is what I have but wanting to know what the amp/watt draw is so I can match the correct fuse rating to the lights
Yes and no I had extra indicator LEDs on my mirrors and this played up no end with my electronics- hyper flash/screen sensitivity. I removed 1 set and left a small set in place no probs.
I have other accessories that I want to use with the block there’re by negating any other possible faults.
(I will get the fender lights to go/off with the indicators as well)
Thanks
If you are wanting them to blink with the signals how would you get that signal if you didn't tap into the signal wire? We have an 11 RTS and I had to run the wire up and tap into both of the wires just behind the plug for the mirror signals.
2007 M109R LE - To many MODS to list. Its cheaper that way!!!
Hi: yep but using the negative wire (home made plug n play) through an off relay.
Power to the lights comes from the relayed fuse box, though another power relay. Using the negative side as the actuation and the power side running through this relay. The negative wire on the indicator side is where I will tap into using home made plug n play plugs thus off/on etc.
Hope this makes sense
Thanks in advance
Hi again all - can anyone tell me the draw amps or watts for these either single bank or together. Cheers
