Results 1 to 15 of 15
    Dec 2020
    Greer, SC
    Default Brake Failure Warning on 2008 Spyder. Dealer gave up
    Hello, I own a 2008 Spyder. I bought it new and got one of the first ones. I have about 7,800 miles but I’ve run into an issue. I have a brake failure warning light that won’t turn off. I just brought it home from a certified BRP dealer. The bike spent 6 weeks there and they gave up unless I wanted to start replacing the ECU and other big prices items they said. They said to enjoy the bike with the warning pretty much. They did a brake bleed, new tires/wheels was done last year, battery, brakes/pads, fluid topped off. It didn’t help. Any suggestions? I greatly appreciate it!
    Feb 2012
    Spring City,Utah
    You said they did a brake bleed,did they replace the fluid? It should be done every 2 years regardless of mileage.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Quote Originally Posted by Rach4life View Post
    They sure did a lot of things .... and didn't fix the issue .... I think they are a bunch of idiots, sooooooooooooooooo take off the brake reservoir caps ( and note how the caps are oriented, so you put them back on the same way ) ..... see how much fluid is in them and if not full, add a couplie of tablespoons of BRAKE fluid to each reservoir .... if you spill any wash off immediately after re-placing the caps ( correctly ) .... It may take a few start - ride a bit - and stop repeat to get the warning to clear .... good luck .... let us know if this worked ..... Mike
    Bossier LoUiSiAna
    on the early ones 6 weeks at dealer in summer with Covid mess ya sure they got a headache or two & needed the space.
    You did check what they claimed was done? There are other parts like sensors that fail before ECU (had one fail on a’13 w/more miles)if you have the time find a second opinion. Maybe open a case with BRP cares not even 10k miles they might be little more insightful Hopefully. **also double check V slit inside caps pointing to the back of bike**
    Aug 2017
    westvville,SC
    Press brake pedal first click is brake lite switch if you get 2nd click that indicates low braking pressure usually caused by contaminated brake fluid. cure change fluid.
    second brake reservoir caps have to be put on in a specific orientation or will not let fluid flow to master cylinder. If you are doing work your self get a set of speed bleeders, makes changing fluid one man job. Had this problem on 09.
    Sep 2008
    Yorktown, VA
    Did they reset the low pressure switch? Give this a try:
    1) Turn the key on and press the button to clear the read safety card message
    2) Press and hold the brake pedal past the second click. If you have good pressure this takes a lot of effort.
    3) Turn the key off
    4) Hold the brake pedal until the back light on the instrument cluster goes off (~30sec).
    5) Release the brake pedal
    Now turn the key on and check to see if the brake failure error is gone.
    I use this method following a rear brake bleed when the error appears on mine. I need a new rear caliper it will let air into the system over a long period of time.
    Good luck!
    Bruce
    Yorktown, VA
    '08 Spyder GS
    Dec 2020
    Greer, SC
    Hello, no this didn’t work. Thanks does the tip though. I’ll check the other replies as well. I must admit I’m not quite handy though. I’ll check to see the work sheet as well. Thanks all
    Checking the level on the brake fluid per BK above is a good suggestion. I have had that happen many times and usually a teaspoon down will do it. A quick, easy, and inexpensive fix most of the time.
    Nov 2015
    Chardon, OH
    When the brake failure warning is Active on your display, then there will be an Active trouble code stored that will be useful in diagnosing the issue. The dealer should have checked that and it may be listed on the paperwork. If not, you can call it up yourself.
    With engine running and the warning active;
    Press the mode button repeatedly until "engine hours" (total hours) shows on display. Make sure you do not release the mode button when you get to "engine hours"
    While still holding the mode button. Flash high beams 5 times within 2 seconds.
    If there are no active faults "No Active Fault Code" will be displayed.
    If there is an active fault, an alphanumeric code will be displayed.
    If there are more than one active code, you may press MODE to cycle through them.
    Put the code in the forum’s search box in the upper right. More than likely you won’t be the first one and there will be a ton of information that you can check on when able. Let us know.
    Doug
    ”Freedom is not a loophole”
    Active Member Claire's Avatar
    Jul 2019
    Georgia
    my 2009 is my daily ride and I add a tablespoon of brake fluid approx every 10 days. At one point my parking brake was not working properly and would not come all the way up each time when I tried to release it. I replaced the springs and little gear thing. but I dunno if parking brake going haywire can give that message.
    I do know after having this bike as a daily ride for 2.5 yrs --- keeping the brake fluid level in the front reservoir so the float pops up like a little bobber keeps the brake failure message away. I also wrap a small thin rag around the cap so any fluid that does come out of the cap the rag soaks it up. good luck!
    2009 GS SE5: Stage 2 Elka front shocks, BajaRon sway bar, K&N air filter, kuryakyn foot pegs, TricLED rear and front lights.
    Mar 2020
    Western New Mexico (Thoreau)
    Hello, I had a 2008 Spyder RS with this issue. Found that the brake booster/reservoir was the issue, worked but sensor detected a pressure issue. Replaced the unit and all was fine? I was just purchasing the Spyder, so dealer covered parts and labor! Good luck.
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    I'm being very ignorant here.
    I also have an 08GS and have never seen a booster/reservoir on mine. A reservoir yes, but not a booster that detects pressure.
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    Mar 2020
    Oldgoat, when I said brake booster, meant the master cylinder. The dealer I bought bike from just replaced the whole unit to solve the brake light issue. Thanks for catching my description mistake! Rach4life, good luck on solving your brake issue.
    Thumbs up
    Quote Originally Posted by Don60 View Post
    no problem
    Sep 2021
    KY
    Default Same On 2013
    Not all the time but just once in awhile. Checked in the master cylinder and there is a plastic ring just floating p. Is that normal?
