Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
  1. #26
    Feb 2020
    N. Wilkesboro, NC
    I just jacked up the rear of the bike and laid down next to it (not an easy task these days) and slowly spun the rear tire around, first looking for anything caught in the rear sprocket then checking the same on the belt, both tooth side and other. Nothing. I guess the shop will have to figure this out unless I happen to have a rock stuck in the front sprocket (I'm no longer equipped to remove that many body panels).
    I appreciate all the help, guys. This is baffling although I'm sure someone who knows these bikes in and out will take about 10 minutes to say, "there's yer problem".
  2. #27
    Active Member wingit3611's Avatar
    Dec 2016
    Louisville, KY 40214
    Woodaddict in note #20 mentioned Dyno Beads clumping. I had that and it was caused by the MOISTURE from my air compressor air mixing with the dust in side the tire to clump with the Beads. Didn't know they were clumping till I wore the tire out. So I guess they still work. Just wanted to share that.
    Can Am 2013 RTL SE5
  3. #28
    Feb 2020
    CT and ME
    I'll echo what Peter said about beads not always being enough. I replaced my tires with the new Quatrac's and put the standard 2 oz front, 3 oz rear Centramatic bead kit you can get on Amazon. I found that my right front wheel was shaking most of the time. Seems like sometimes the beads worked but other times they did not and was inconsistent. I supposed I could have just tried adding more beads but I decided to remove the beads and re-balance with weights. Now it's smooth as silk!
    By the way, Marc Parnes sells a nice balance kit specifically for the Spyder. http://www.marcparnes.com/Can-Am_Spy...l_Balancer.htm
    Oh and also, these new Quatrac's are fantastic. Tremendous grip on curves! I also noticed that the Spyder is less squirrel-y on gravel roads than the OEM Kendas.
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
  4. #29
    Feb 2020
    N. Wilkesboro, NC
    Just got back from the dealer. They dismounted the tires, removed the beads, remounted the tires and balanced everything. Smooth like it should be. They said another couple ounces of beads probably would have taken care of things but I'd rather the tires be balanced the "right" way.
    Thanks for everyone's assistance, posts, etc.
  5. #30
    Oct 2016
    Sebring, FL
    Interesting Monk, makes me wonder about the beads. I'm tempted with the Ride-On product.
  6. #31
    Feb 2020
    N. Wilkesboro, NC
    Bill---I think I just didn't have enough beads.
  7. #32
    Sep 2017
    INDIANA, USA
    Default RT Spyder
    Hey Monk, what year and model is the Spyder.
    ENJOY YOUR LIFE WITH A SPYDER
  8. #33
    Oct 2016
    Sebring, FL
    Gonna miss you around here.
  9. #34
    Feb 2020
    N. Wilkesboro, NC
    Quote Originally Posted by Little Blue View Post
    2021 RT
    You trying to get rid of me, Bill? I hadn't planned on going anywhere. I just can't ride much anymore.
  10. #35
    Oct 2016
    Sebring, FL
    Oh golly gee whiz, not at all my friend, just thinking u might lose interest. So will still look for your comments.
