Results 1 to 10 of 10
    Active Member Indyron's Avatar
    Apr 2013
    Sunbury, OH
    Default HELP S2S Won’t shift into reverse
    Won’t shift into reverse any ideas guys?
    2021 Sea to Sky, 2013 RT Ltd, 2005 Bombardier Outlander ATV
    Nov 2018
    Waynesboro, PA
    Foot on the brake?
    My Spyder
    2012 RTL , Brown
    Nov 2015
    Chardon, OH
    Thumb on the "R" button?
    Doug
    ”Freedom is not a loophole”
    Feb 2017
    It's a Sea to Sky so I would assume it should be under warranty. The solution rightfully is the dealer's.
    Dec 2013
    Could this be another 20/21 Spyder with a dickie Left Hand Control Module??
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Very Active Member JKMSPYDER's Avatar
    Dec 2012
    Murphy, NC
    It could be the left hand control module or the reverse lockout switch.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Spyderpops Brake/Run/Turn Signal LED's
    Lamonster Garage LED Fog Lights and Headlights
    2013 ST-S retired 1/9/16 at 25,061 miles
    2015 F3S sold at 77,565 miles.
    2015 F3-S , BajaRon Plugs Can-Am Red
    Jun 2021
    Bossier City, LA
    My '21 RTL sometimes did this when I first got it.
    My throttle will sometimes stick, so that the bike is "idling" at around 1300 RPMs. This is something that will be addressed in my first service).
    If the throttle isn't truly at idle, then no matter how much I push the "R" button or the paddle, it will not shift. I now make sure that I am truly at idle.
    --Exco
    Jun 2016
    Harrington, Australia
    You aren’t pressing both buttons at the same time are you? I found I have to press the reverse button and then the paddle.
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Jun 2016
    indpls in
    tighten up your parking brake cable just abit to take the slack out
    Jun 2016
    indpls in
    did that work for you
