Results 1 to 4 of 4
    Aug 2021
    NV
    Default Stuck in reverse
    Hello everybody,
    I have a 2009 can am spyder rs, I did an oil change and coolant flush about to days ago. Everything went smoothly with no issues, I pulled her out of the garage using the reverse switch and when I went to put her in 1st gear she would not change over, I tried other gears but with no success. Does anyone have any clues to what might be the issue. Please help!
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    The reverse actuating cable passes right next to the oil filter cover. Check to see you have not damaged it in any way.
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    May 2018
    Chateauguay, Qc, Canada
    You have not said whether or not it is an SE5 or SM5. If it is an SE5, it will be sensitive to the oil level. Check the oil level as per the Can Am procedure. to assure this is not the cause of the problem.
    I am not conversant with the SM5 so I can't suggest any course of action.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    Have you disappeared?
