Results 1 to 8 of 8
    Very Active Member redneck diva's Avatar
    Oct 2013
    Covington, Ga
    Default 2021 F3 Limited seat removal
    i just recently brought home my 2021 F3 Limited. I have a sheepskin cover i want to install on it. does anyone know how to remove the driver seat??
    Redneck Diva
    Member of the Southern Cruisers Riding Club Chapter #213--
    Central Georgia
    Proud PGR rider
    Aug 2013
    SF Bay Area
    My Manual said to use the key to pop off the passenger seat then use a 10mm socket to remove the two bolts holding the rider seat.
    2021 F3 Ltd , Magna Red
    Harrington, Australia
    Yep………and when you are using the 10mm socket, I would advise holding a telescopic magnet next to the bolt. It is very easy to accidentally drop the bolt into the “black hole”, never to be seen again, Diva
    HeliBars Handlebars
    Kenda Kanine rear.
    ……..oh….and when putting the rear seat back on, make sure its two front arms are lined up perfectly with the receptacles in the front seat……it can be a real bear.
    HeliBars Handlebars
    Kenda Kanine rear.
    Jan 2021
    northeast pa.
    i wrap tape around the socket and the extension so it cant come off,,, easy/peasy
    2020 F3 limited, liquid titanium
    grip puppies
    Bajaron sway bar
    lamonster belt dampener
    battery tender
    19 in freedom tinted windshield
    matte black daytona frunk wrap
    Quadtrac 165/60's
    Feb 2016
    We have a 2021 F3L that for some reason came with plastic pushpins where the 10mm bolts should be. I've since corrected that issue. If you find that yours came with the push pins, you'll need to buy two nutplates and bolts. I got them at the local hardware for far less than it would have cost to drive to the dealer to have them put them on.
    2020 RT Limited , Marsala Red
    Hmmmmmmm. I imagine it would be a bit testing to get pushpins out in that space, Jetfixer.
    HeliBars Handlebars
    Kenda Kanine rear.
    Active Member ChicagoSpyder's Avatar
    Chicago
    I'm guessing the reason was a cost saving measure.
    2018 F3 Limited , Black/Chrome
