Results 1 to 8 of 8
    Jul 2021
    BC
    Question Windshield out of cycle sync after arm / gear replacement
    Hi everyone,
    2019 Spyder RT Limited:
    I had to replace 2 windshield arms and repair a mount on the WPM. All good except that I must have installed the lift arm out of its original position. It complained, threw a code as it topped out.. c222b.. (IIRC). It stopped working altogether. Tested the motor with direct power. It’s ok.
    Took the arm out, repositioned it, now it only goes up. Kinda useless.
    How do I reset its cycle? The code is gone, but I wouldn’t mind clearing the memory of it anyway.
    Any suggestions?
    G
    Sep 2014
    USA
    Did you put the magnet in correctly? That stops the up and down.
    Active Member noboot's Avatar
    Sydney Auustralia
    Quote Originally Posted by SuperGee View Post
    Hi everyone,
    Any suggestions?
    G
    We have seen this problem before and in every case take the arm back off and rotate it 180°
    See here:
    https://www.spyderlovers.com/forums/...16#post1587516
    Jul 2021
    BC
    I didn’t see any magnet. I’m not sure if there’s one in this assembly.
    Jul 2021
    BC
    Ohh no… real time realization that I’ve royally screwed up. I may have broken the magnet. I was quite certain I put the arm back on correctly. That new gear I put on isn’t going to come out without a fight. Hell, I had to cut to old one off.
    Cruuud…
    Thanks for the info. I wish I had done a bit more research on this attempting this repair.
    G
    Sydney Auustralia
    There is a video at the bottom of this web site that helps with the process http://ozspyderryders.com.au/spyder-items-for-sale/
    Durham,Maine
    Good luck SuperGee, I just did one on my bike, got one of Ron's works of art, and followed his video almost to the tee, had only one snag, I broke that tiny little screw in the end of the the shaft off just a pinch above the surface! Luckily a friend of mine had a good set pliers and a torch, burnt the Lockite out and unscrewed the nub out!!! Hew Working fine now!!! Thanks again Ron!!!
    2012 RTL , Pearl
    Sep 2014
    USA
    You have to buy the whole unit. You cant get parts for that area. except the arm
Tags for this Thread
