Results 1 to 20 of 20
    Member kennyscot's Avatar
    Aug 2021
    Perthshire
    Default Trying to get License Plate Light for CanAm RSS 2012
    Hi everyone, first post here and it has to be because I am looking for a part.
    I live in Scotland and have phoned all the dealers looking for a license plate light, part number 710001993 but none have any in stock and the part is listed by BRP as vintage and has to be ordered through vpartsinc.com None of them can do this for me as BRP won't let them do it and have said that i to do this by myself. I tried ordering direct at vintage parts but have to be an authorised dealer. Does anyone know of any dealers I can go through to get this part or am i better to replace this with something else.
    Had a similar issue recently trying to get Kenda fronts, none available in the UK so have gone for Michelin cross climates (being fitted next week)
    Aug 2021
    Perthshire
    Default looking to replace license plate light Spyder 2012 RSS
    Hi everyone, this is my first post and I am wondering if you can help.
    I live in Scotland and I am trying to replace the License plate light (710001993) , have phoned all the dealers in Uk but they none in stock and the part is listed as vintage by BRP on their stock lists so has to ordered through Vpartsinc.com None of them are allowed to do this according to BRP uk and they have all said that I try ordering from someone in USA or Canada. I tried ordering from VParts (vintage parts) and set up an account, but you have to be an authorised dealer at the checkout to buy anything.
    Does anyone have any dealers I can go through to get this part?
    (ps it was bad enough trying to get kenda fronts for the RSS!, none available in the UK at the moment so going for Michelin CrossClimate)
    Quote Originally Posted by kennyscot View Post
    Well not having a KENDA tire is a hugh PLUS ..... The " cross climate " is one of , if not , the BEST tire you can get ..... As to the License plate, I would find a small LED that can be found at any Auto parts store ...... good luck .... Mike
    Nov 2015
    Chardon, OH
    So, Kenny. You are looking for the entire light fixture and not just the bulb, correct? Honestly, I'm looking at parts diagrams and the 2013 light looks identical to the 2012 light on those diagrams. It's just that in 2013, there was a difference between the European light and the US light, and it got another part number. But, it still looks the same as it did in the 2012 diagrams. Would the 2013 light - 710003349 - work on your 2012? These are definitely available.
    Doug
    ”Freedom is not a loophole”
    Apr 2011
    GREENVILLE, SC
    GOOD LUCK FINDING ONE.....
    i think i got the last one from CUSTOM DYNAMICS....
    however, i've made no less than 5 of them for myself and friends... a little sheet metal, some plastic, red spray paint n heat gun and a bit of effort and you'll be fine....
    20181231_121927.jpg this is from CUSTOM DYNAMICS
    this is one of the ones i made for a friend
    Aug 2021
    Perthshire
    hi everyone
    Really appreciate all the posts and comments, its good to know you can reach out and get help. Following Mike's advice found this which seems to match within a few mm the part that I am trying to replace
    https://www.ebay.co.uk/itm/233422340...sAAOSwGzhaIC0N
    When I get it fitted will take a pic to let everyone see, not ideal as I was wanting to keep everything original but sometimes its just not possible i suppose.
    Kenny
    Aug 2021
    Perthshire
    Hi Doug
    Thanks for suggesting that, I have looked at the parts diagrams and as you said the part looks similar to the 2015 model, will go back to the dealers and see if they come back with this as vintage as well!
    May 2021
    Nevada
    2021 Sea to Sky , cyclops light, front fender light/turn signal, rear run/brake/ turn signal LED strip, BRP floor board light Green
    Aug 2021
    Perthshire
    Hi Guys
    went back to dealers and did what Doug suggested and asked if the light for an 2015 RS/ST came up in the stock list as vintage as well – it came back as available in stock so got it. Turns out only difference is the connector plug to the wiring harness, but the plate cover is exactly the same so it just screwed that on to the one already on the trike, now got it back to original.
    I had made temporary cover out of the lid off a plastic business card box, it was nearly a good fit and didn't look too bad but having the right thing is better, now a happy man again!
    posting a few pics to let you see
    Active Member obiwanbill's Avatar
    Apr 2009
    toledo ohio
    eBay?
    Former Navy LT, Retired Chemical Dependency Therapist, Retired Widower, "Do, or do not, there is no try"... Jedi Master Yoda.
    Proud member of AA, PGR, and a Navy Shellback!
    2020 RT Limited Chrome , matte black trim, Green/gray Charcoal? depends on the lighting
    Active Member ChicagoSpyder's Avatar
    Chicago
    Here you go Kenny, more than 10 available.
    https://www.ebay.com/itm/393461744126
    2018 F3 Limited , Black/Chrome
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    I've got the number plate fitting with the license plate light in my shed as I replaced my rear mudguard etc with the tail piece off a motorbike. I'm guessing its the same part as the UK one so if you get really stuck I can post it over.
    Only issue is that we're currently in level 4 lockdown as we've had a Covid outbreak in the North Island. Post offices etc are closed so it could be a while before I could post it.
    EDITED: For some reason I only saw first post, but when I posted mine other entries came up in the thread and I see you've already got it sorted with some DIY:-)
    Aug 2021
    Perthshire
    Hi Pistonblown
    Thanks for the offer, as you said got it sorted by asking the dealer to look for parts for the 2015 model parts list and they were listed in stock. also found a trailer light which is close match, only 5mm out in length, depth and height, and it only cost £7 instead of the £70 (when you include shipping) for the original part so now have this as my spare if it breaks again
    Dec 2019
    Kapolei, HI
    Just saw this post. I recently did a rear fender delete and it's sitting in my garage. Assuming the US and European models aren't different, you would have been welcome to it (just pay shipping). Glad your innovation and ingenuity worked! We have no dealer here so improvising and self-help is the rule rather than the exception! Aloha!
    Linden, CA
    Hi Dave here, You will not find one , BRP no longer has them and Custom Dynamics quit making them when BRP dropped the GS-RS-RSS
    I got this at the auto parts store looks like it came on it new and the cost was $6.00 US
    Jan 2020
    Wales
    Hi Pistonblown
    Hi Kenny,
    I have a 2011 rss and have just lost the cover, i am looking at different replacements, i can see i need 75 mm centre to centre for the bolts.That cheap trailer light you have does it fit? and could you post up a link for it if possible.
    TIA,
    Aug 2021
    Perthshire
    Quote Originally Posted by Welsh1 View Post
    Hi Kenny,
    TIA,
    Hi Dave
    just seen your post, will try and find the info for the part i bought, it was for an Ifor Wlliams trailer
    Kenny
    Aug 2021
    Perthshire
    Hi Welsh1
    have found the info, this is what ia bought as a spare for the spyder, its a close fit but you might have have to adjust/drill new holes
    https://www.ebay.co.uk/sch/i.html?_f...40687&_sacat=0
    Did you try and use the part number for the 2015 RSS when looking or contacting dealers, its the exact same as the 2011 part just different part number. When asking the dealer using 2011 part number luck, when using the 2015 part number one was in stock, only thing is the part cost £74 including postage compered to £6+postage for the one from eBay.
    Hope this helps you along the way to finding what you need
    Kenny
    Active Member Nokesy's Avatar
    Mar 2017
    Newmarket
    I had mine break off while in Quebec last year, I call my Dealer "ST Onge" in Barrie, Ontario and they had one in a week for about $70 Canadian. Hope that helps
    Done all of Canada except NWT and parts of Australia, New Zealand and areas of Europe
    Quote Originally Posted by Nokesy View Post
    Probably won't help the original poster now Nokesy, considering that the original post was put up in August 2021!
    Even the last few posts in this thread (those immediately before yours, anyway ) were put up waaayyy back in December 2021, which once more highlights why it's so important that you
    It ALWAYS pays to check the date on the first post in a thread AND the dates of the last half dozen or so posts before you reply to a thread!! That way you won't get caught out quite so often (cos we all do it and probably will continue to do it every now & then ) but at least by checking the dates, you're likely do similar 'thread archeology of questionable benefit due to the time that's passed since the question was asked' juuust a little less often, which might save you from looking quite so far behind the times!
    Just sayin', so you and other readers/potential posters can learn.
    Cheers
