Page 2 of 2 FirstFirst 12
Results 26 to 27 of 27
  1. #26
    Jul 2023
    S.E. Pennsylvania
    Took the bike in to have the dealer look into the brake failure fault codes C0042 and C1182. After pronouncing the bike "good to go" I turned on the ignition, without starting the motor, and the error codes reappeared. I left the bike with them overnight. Once I got home I Googled the codes and found that BRP has a service bulliten on these codes.
    It is BRP Service Bulletin 2020-6. I down loaded a copy and sent it to general manager.
    I have picked up the bike and have not seen the fault codes (yet). Time will tell.
    Lee B
    2022 Can Am RT Limited
    2021 Honda NC750X DCT
  2. #27
    Member AE2WM's Avatar
    Jul 2021
    Chimacum, Washington
    I had the brake failure annunciator come on, telling me my fluid level was too low. Did a visual inspection: it was fine. I replaced the sensor, a magnetic reed switch. Problem came back a day later. Found that the connector between the sensor and the wiring harness was intermittent. I wired around it and the problem went away, never to reappear.
    Bill McGrath
    1962 Matchless G80 500cc Single
    1967 Norton Atlas 750 with Dunstall kit
    1972 Honda CB450
    1981 Honda XL500R
    1983 Honda 750 Sabre
    1987 Honda 1100 Sabre
    2002 BMW K1200LT
    2021 Can-Am Spyder RT Limited with BR anti-sway bar and Garmin Zumo XT
    1969 Cessna 182 w/STOL kit, fully IFR
    2021 Spyder RT Limited , Petrol (100LL if you're a pilot)
