Results 1 to 2 of 2
    Sep 2009
    La Valle, WI
    Default Spyderpops Led turn signal question.
    I have an 2018 F3L. I installed the Led turn strip that gos under the side vents where the service covers are. I have trouble seeing my turn indicators cause I have the short reach handlebar. Well I bought these on the recommendation I could see them flashing. Well I dont unless I'm looking down at them. I see the plug and play harness has 2 connections for another strip. Is there a shorter strip than has a harness long enough to reach my center dash. I want to wrap them around the groove in the cluster cover. Right in front of me. I need it to be 8" or less. I would not think you could cut off to the length you need or can you.
    2018 F3 Limited , Oxford Blue
    Northern Kalifornia
    You'll have to ask Spyderpops about cutting the light strip. All of my Spyderpop's light strips are failing. They go out 3 LEDs at a time. Maybe you can cut off 3 and the rest will still work? I put my LED strips on the rearview mirror housing.
