Results 1 to 7 of 7
    Oct 2020
    Arizona
    Default C0031 and C006C resolution/fix
    So a friends 2017 RTL sat all summer while she was away. When she went to use it, it went into limp mode and had the C0031 and C006C error codes. Brake fuild was low, and when topped off the problem was still there. All the light worked fine and brake switch was not stuck on. After check everything that tihis and other google search recommended I started looking at the ABS sensor cable on the left front wheel. A neighbor down the street had mice or rats eat up a bunch of wiring on the same year, model and Champagne Color.
    Well what I found was mices had eaten throught the wire completely inside the frame pass where the upper A-Frame attaches. I removed the cable and repaired it as a test. Reinstall and it, fired it up and no limp mode on C0031 and C006C. I gave me the part number to order a new sensor/cable.
    To disconnect the sensor cable, slide the grey clip out and then sweeze it.
    Oct 2020
    Arizona
    The out jacket on this sensor wire is very tuff, but not to mice.
    Oct 2015
    Lynden, WA
    Nice work. I love DIY repairs.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Sep 2012
    Stetson, Maine
    Great job on finding and repairing the cable. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Durham,Maine
    I am a cheap bugga, if the wire was long enough, I would have soldered and heat shrinked the conection and called it a day!! Good work on the diagnosing work!!! Good Find!!!
    2012 RTL , Pearl
    Oct 2021
    Wichita, KS
    Quote Originally Posted by Snoking1127 View Post
    So I guess what we learned here is mice like 2017 Champagne colored RTL's
    Peter Pan has struck again!
    Quote Originally Posted by FrogmanDave View Post
    It's gotta be the fizz they get from the champagne.... or was that from the battery??
