Results 1 to 4 of 4
    Apr 2021
    WV
    Default Help! Sequential Fender LED's
    Hi I bought the Sequential Fender LED's from Value Accessories. Took all the tupperwear off that is necessary. This is supposed to be plug and play except on my 2019 Spyder RLT which has a single wire that you T-tap connect to your mirror harness positive wire. I did all that and these lights will not blink, they come on as running lights. Also I plugged the mirror back into the harness and it blinks as usual, nothing but a steady glow from the leds on the fender. I'm glad I haven't drilled holes in my bike yet, thought I should mock up the wiring to see if it works first. Nope, I still have the bike torn down, thinking I may just send these LEDS back and forget it. I changed out the harnesses for lights with the one for the other side, no change. With a volt meter I get fluctuating voltage when signal is activated as it should to blink but no blink on the LEDS. Help please. Thanks in advance, Jim.
    Last edited by Peter Aawen; 07-29-2021 at 07:53 PM. Reason: Removed Prefix - this is a 'How do I?' question & not a 'How to:' DIY explanation....
    Bossier LoUiSiAna
    Well definitely call customer service before removing or sending back They might have encountered this issue before. Fact you do get some light is encouraging.
    Apr 2021
    WV
    Default Solved
    Rick called me from Value Accessories and suggested I recheck the black wire that runs from the led harness to the mirror harness on 2019 Spyders. Bingo the Ttap wasn’t right and it now works.
    Hats off the Rick at Value Accessories top notch customer service after the sale!
    We appreciate hearing back when a problem gets solved.
