Results 1 to 24 of 24
    Member stocktoy's Avatar
    May 2017
    Canada Coldwater, Ontario
    Default recommended front replacement tire
    Looking for a replacement front tire Federal Forma 0ZA not available in Canada right now any other recommendation's?
    thanks for any help with this
    Richard
    Quote Originally Posted by stocktoy View Post
    Richard
    If you only buy ONE tire it really needs to match .... if not steering / handling issues will happen and the tire you have better not have a lot of wear on it ..... Why only one tire ???? ..... Mike
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    They need to match, as Mike states (he's usually right) I have michelin cross climate's in the front, 175/60 R15, dunno if they have them in canada, but these tyres, I like them allot.
    There are alotta options, but most are better then the kenda tyres
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Active Member FlyBoy2121's Avatar
    Aug 2018
    Canada
    I Guys
    My English is not very ggood
    Many brands of tires you have in US we don't have here in Canada, they don't sell a lot.
    I bought Kenda Kanine KR20 that I had installed in an independent workshop,
    I can't give you an account of their efficiency, but after about 160 kilometers its much better than the original Kenda scrape, and I had the lazer lined up.
    FlyBoy2121
    2014 RT ltd , original original Cognac
    Active Member Rednaxs60's Avatar
    Mar 2021
    British Columbia
    Just changed my front tires from the OEM Kenda, still in good condition after 16K Kms but going on 7 years in age, with 155/60R16 Kuhmo Solus KH16 tires. 98 percent match, just a shade narrower. Same price as the OEM Kenda, non-directional, good tread profile. Reason for Kumho - availability in my area. These tires are used on Smart cars. Inflated to 22 PSI. Good luck.
    "When Writing the Story of Your Life, Don’t Let Anyone Else Hold the Pen"
    "Too many of us are not living our dreams because we are living our fears.” – Les Brown
    2014 Can-Am Spyder RT LE
    1985 Honda GL1200 Goldwing Limited Edition
    Ernest
    May 2017
    Sorry for not being clearer I'm looking to replace both front tires as they are getting close to the wear bars. Board suggestion was to use the Federal Forma 0ZA
    they are currently available in Canada so looking for another tire to use other then stock tire.
    May 2017
    Thanks for the info I will check into their availability in my area.
    Richard
    May 2017
    Mesa, Arid-Zone-A
    It's pretty hard to give you good advice because you didn't say what you ride. And, there is nothing in your profile to help us..... Jim
    Semper Fi
    May 2017
    Sorry for that omission canamjhb I ride a 2017 RT Limited with 26,000 kms or 16,000 miles on it.
    May 2017
    Mesa, Arid-Zone-A
    That helps. If your problem finding tires because of limiting size, there are other size options that work also. Your RTL has the "new" style front fenders. That's what I had also. I went with 175/55R15 tires and they fit just dandy. A little bigger than the OEM size and they looked/handled really great. They fit without any modification. The one thing I did was to snip 1/4 inch off the fender attachment bolts. They are unnecessarily long and intrude into the wheel wells. I took one out at a time and snipped the ends off. Three per side and took maybe 10 minutes. Probably not necessary but I just wanted to be safe.
    Again, you don't need to limit your tire search to only the size that was OEM. And, any tire you use will make you happier than the Kendas. Good luck..... Jim
    Semper Fi
    Jul 2021
    IL
    I've read several threads on the subject of tires, but as a new Spyder owner I am curious as to what is disliked about the OEM Kendas? I've only put about 1,400 miles on the 2021 RT that I've had for a month, and so far I cannot say I am displeased with how they handle. What am I missing?
    2021 Spyder RT
    2023 Royal Enfield Hunter 350
    Retired U.S. Army
    Life Member, NRA
    2021 RT , Petrol (blue)
    Member GoldenSpyder's Avatar
    Feb 2018
    Northeastern N.C.
    My RT-S had Kenda tires when I got it and they started to "cup" early on, even though I had them balanced and had the alignment done. They also tended to wear on the inner edge of both tires. I changed them at 14,000 miles to Continental ContiProContact 165/55R15 and have plenty of room under the fenders. These tires are non-directional and about every 2,500 miles I swap the left with the right and run the tires backwards. This seems to help with wear. They handle GREAT and are good in both wet and dry conditions. I usually ride solo and run 19 p.s.i. in them. So far, I have 28,000 miles on them and they look almost like new. VERY pleased with my choice of replacement front tires!
    2014 RT-S SM6 , Circuit Yellow
    Quote Originally Posted by vito1943 View Post
    IF your Kenda's are NOT defective they are Adequate, not great, just adequate..... with good alignment expect about 22 to 25,000 mi. .. But the Rear tire is only going to last ( on avg. ) 12 to 15,000 mi.... Mike
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Richard
    Where in Canada are you located I would highly Continental Pro Contact 175/55/15 46000 miles on mine so far still like new
    May 2016
    Mansfield, Ohio
    I used Federal 595 Evo 165/55R15 on my '15 ST Limited and they worked great.
    2021 RT Limited , Deep Marsala Metallic (red)
    Member Circ's Avatar
    Jul 2021
    South Dakota
    I don't know about availability in Canada but lots of folks here (Spyderlovers) seem to be pretty happy with the Vredestein Q5 or Quatrac. I do not have experience with them but based on my research I will be putting a set on my fronts very shortly.
    May 2017
    I hope this reply works or I've now replied 3 times lol.
    Thanks to all that took time to reply with suggestions. I got Continental's for the front and a General for the rear.
    Richard
    Quote Originally Posted by knobby View Post
    At Lamonster's recommendation I switched to the 595 Evos and presently have 27.9K on them and they are still doing fine.
    Mar 2019
    NEBRASKA
    Continental ContiProContact All-Season Tire - 155/60R15 74T https://www.amazon.com/Continental-C...04QGZM3O&psc=1
    Are these too narrow ?? Quite a bit cheaper
    2012 RTL 14 RTS , Pearl White @ Pearl White
    Quote Originally Posted by davev1pa View Post
    Will it fit - yes .... will it work -yes ..... but not the best you can get for that cost !!!!..... Look at what tirerack.com has for ratings on this tire ..... I'll save you some time - they are rated " good " .... good luck .... Mike
    Aug 2019
    TX
    These are great tires. Just wish I could find them available..seems there are no tires available for a spyder other than the rear Kumho!!
    Quote Originally Posted by Bottomline2000 View Post
    Well the Vredestein Quatrac is probably the Best tire currently available for any Spyder .... I did some searching thru your past posts ..... If you think your rear Kumho is good at 25 lbs. psi try it at 18 psi .... it will amaze you much better it rides ..... jmho .... Mike
    I found some 595 Evos on some obscure web site, several pages down in the search, for about $88/tire but since I didn't need didn't bookmark it. It seems right now most all brands are back ordered or listed not available.
    Mar 2019
    NEBRASKA
    TireRack.com
    Tires
    General AltiMAX RT43
    Availability: In Stock
    215/60R15
    Style: Blackwall
    Serv. Desc: 94T
    Qty
    Price Each
    Item(s) Total
    Assign Vehicle
    $101.99
    $101.99
    Includes Free Road Hazard Protection ($9.88 value. Two-year coverage.)
    Free Shipping
    Save for Later
    Sub-Total:
    $101.99
    Vredestein Quatrac
    Vredestein Quatrac
    205/60R15
    Style: Blackwall
    Serv. Desc: 91V
    Qty
    Price Each
    Item(s) Total
    Assign Vehicle
    $101.62
    $101.62
    Includes Free Road Hazard Protection ($9.84 value. Two-year coverage.)
    Free Shipping
    Save for Later
    Sub-Total:
    $101.62
    Vredestein Quatrac 5
    Availability: Back Order
    165/60R15
    Style: Blackwall
    Serv. Desc: 77H
    Qty
    Price Each
    Item(s) Total
    Assign Vehicle
    $84.41
    $168.82
    Includes Free Road Hazard Protection ($16.36 value. Two-year coverage.)
    Free Shipping
