Results 1 to 6 of 6
    Member 2katz's Avatar
    Jul 2021
    Spring (Houston), TX
    Default 2021 F3 Limited Horn upgrade
    I’ve been researching horns to upgrade the puny horn on my bike. Everything I find notes they fit pre 2020 model's.
    Two questions:
    - Is there ‘that’ big of a difference in the current model vs. older, that would keep a horn from being installed? It already appears that I would need to relocate.
    - I do want a two tone horn. I don’t see much of a difference (sound, physical appearance or reviews) between the Wolo Big Boy and the Stebel Nautilus Compact. Is one really better than the other and/or is the another manufacturer I’m missing entirely?
    While a train horn is an option, I don’t like how far it would need to be mounted off the frame to clear the panels.
    Once again, thanks for your insight!
    I ‘think’ this is the last upgrade for awhile. After I install a few items coming in this week and the horn, I’ll update my signature, noting all upgrades and include a photo.
    2021 F3L Black/Chrome
    LAMonster:
    Ultimate Backrest, Bottle Holder, Baja Ron Sway bar, Cat Delete Pipe, Freedom Windshield, Highway brackets/Black Demond pegs, Upgraded Tension Roller, FOBO Tire Pressure Monitor
    TricLED:
    Sequential LED Spyder Fender Lights, Run/Brake/Turn Strobe Light Kit, Brake flasher
    SlingMods:
    Chrome Luggage Rack
    Pedal Commander
    Spyder Accessories.com:
    Tank Pad
    Amazon:
    Ciro phone holder/mount, Stebel Nautilus Air Horn/Wiring Kit, Short Reach Handlebar
    Feb 2019
    Portland, Oregon
    Which ever horn you get, be sure to use a relay. I added a fuse block to attach all electrical accessories to avoid the bike's fussy electronics. Here's a photo of my dual car horn installation on the back wall of the frunk, above the battery. Note the fuse block between the horns.
    Jul 2021
    Thanks for the reminder re: the relay. Hubby says I really need one to ensure the horn can reach it’s full potential!
    LAMonster:
    TricLED:
    SlingMods:
    Chrome Luggage Rack
    Pedal Commander
    Tank Pad
    Amazon:
    Active Member VitoNam's Avatar
    Nov 2018
    NW Minnesota
    Try a search here for: Horn Upgrade or WOLO Horn. Lots of info!
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by 2katz View Post
    That, and not melt the switch.
    Mar 2017
    I installed a set of goldwing horns in the cavern under the frunk liner. Got them for less than $20 off eBay. Had great result with that. One must be aware that the OEM horn is switched by the ground wire, the hot +12v is always hot with the bike on or off. I'm showing the necessary circuit diagram for using a relay to beep your extra horns (if you are not going to run horny strobes ignore any extra wires not hooked to the horns).
