Results 1 to 2 of 2
    Jul 2021
    Alabama
    Default 12 Volt Accessory Plug in Trunk not working - 2011 RT
    I have the 2011 RT Limited and my back trunk’s 12v accessory plug isn’t working. We’ve checked the fuse and it shows good. Can someone help me please
    2011 RT Limited , Pearl White
    Dec 2013
    Quote Originally Posted by Mimi23 View Post
    Got a multi-meter or test lamp that you know how to use?? Test the both the battery side of the fuse and the accessory plug itself, but do each twice - once with the ignition only turned ON, and once with the engine running. The fuse being good doesn't necessarily mean that there's any power reaching it in the first place, so you need to check & confirm that it actually is reaching the fuse; then the plug may only be getting power when the engine is running, so you need to check that too! Please tell us what you find...
    Good Luck!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
