Results 1 to 6 of 6
    Nov 2016
    Arizona
    Default 2014 RSS Frunk release loose from ignition! Help?
    The cable for the frunk latch came loose from the ignition. Is there an easy way to access and put it back?
    2014 RSS
    Thanks,
    Quote Originally Posted by Paul A View Post
    2014 RSS
    Thanks,
    You need a thin ( 1/4 to 3/8 dowel or metal rod approx. 18 inches ) ... then remove the large RIGHT side panel ( not the upper one ).... the latch is in the middle between the lights ..... pry up the right side of the frunk lid as far as it will bend and put something in the space to hold it up ..... un-fortunately there is cover over the Latch .... you need to pry it up so you slide the rod / dowel in and push on the latch LEVER to re-lease it .... having a good LED flashlite with a narrow beam will make this easier ..... After you get it open, think about adding a re-lease cable to the lever so this doean't happen again .... I have one on mine and ALWAYS use it to open the frunk, IMHO the key should not be used to open the frunk ..... good luck ..... If you go to " cheapcycleparts.com " you can find pics of this area so you know what to expect ..... Mike
    Nov 2016
    Arizona
    Thanks
    I have no problem opening the frunk. I'm trying to reattach the cable to the ignition switch.
    Nov 2016
    Arizona
    Default Frunk release
    I have been thinking about adding the optional release. How did you hide yours so you maintain a level of security for the frunk contents?
    Thanks,
    Feb 2019
    Portland, Oregon
    I have attached wires to both frunk and seat latches. I attached a small black pull on the end so they are not seen. Here's a photo of the frunk latch and wire...
    Nov 2016
    Arizona
    Thanks for the input.
