Results 1 to 9 of 9
    Jun 2021
    San Clemente
    Default Adding a 3rd brake light and signal light to a Top Case
    Hi, I've just purchased an LED kit from Admore Lighting for my Givi E450 Top case. By any chance does anyone know what wire color is for the brake light (white?) and wire color for turn signals? I will tap into the rear brake lights of my Ryker to my Givi Top case. Thanks in advance for your help!
    Update: I was able to figure out the wire setup. Everything looks good! Thanks everyone.
    Jul 2020
    Florida
    I added a rear LED brake light flasher last year, but dont remember the colors of the brake wires. Once I disassembled the rear brake light & turn signal panel at the back, I just used a bungee cord to hold the brake pedal down and with a 12 volt tester found out which ones was for the brake light. Then I ran the wiring down along the bottom of the shaft housing (where the factory harness is run) and zip tied my new brake light wire to that harness. Then up and underneath the Max Mount to the new LED brake strobe light. I didnt do an install video, but I did do one showing the light and its different strobe patterns.
    2020 Can Am Ryker Rally Sport Touring Edition
    Dec 2020
    IL
    Slingmods.com sells a plug and play brake kit that goes by the license plate. I bought that and cut the wires and added my own lights. It was easy to figure out which wires were what.
    Active Member sKiZo's Avatar
    Mar 2021
    Michigan
    All too low for max visibility. I've been looking into one of those "smart" helmet stop lights. The BrakeFree light uses a G sensor to activate on ANY decel, super sensitive, and it's supposed to react even to motor braking. Expensive lil thang, but sounds like just the ticket for me.
    Half a million miles, and I ain't dead yet.
    See my album at https://www.spyderlovers.com/forums/...p?albumid=5190
    Sep 2019
    illinois
    Aug 2019
    southwest oHIo
    Quote Originally Posted by justforfun View Post
    Would you believe that Admore Lighting has your answer?
    https://admorelighting.com/how-to-de...v=707f3a40153b
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Jun 2021
    San Clemente
    Great, I'm guessing the rear light wires on a Ryker should be the same as a Spyder. I also purchased a 12v test light. i should receive the light kit next week. Thank you
    Active Member DickB's Avatar
    Jun 2021
    FL
    Jun 2021
    San Clemente
    Quote Originally Posted by DickB View Post
    Looks good. Thank you
