Lowering brake pedal on rt
I have seen several references to the LaMonster shortened brake rod for the F-3 and he shows it on his web site but no similar posting for a shortened brake rod for the 2019 and prior years RT. I have a 2019 RTL - SE6 and would like to lower the brake pedal on it. Unless I lift my foot to apply the brakes, if I try to lift at the ankle and pivot over to the pedal, I get a severe cramp in my leg and ankle. Will the F-3 shortened rod fit on the 2019 RT? I know it won't work on 2020 and newer but I have a 2019 which does have a brake rod. Just don't know if it is compatible with the RT.
What I did to my 2014 RTS after my right hip replacement...I mounted a standard RT foot peg, with a spacer on top of my RTS right flor board...My heel rests on top the foot peg and you just pivot the front of you right foot slightly to the left on top of the brake pedal...NO FOOT LIFTING NEEDED...
Under the floor board rubber mat covering you will see 4 screws towards the rear of the floor board...I removed the 2 rear screws and used longer screw to attach my spacer and rubber peg...
I did try using the further front 2 screw holes and that allowed your foot to pivot in the middle but it did not allow enough lift on the front of my foot to slide in on top of the brake pedal...
I do have a picture...I could e-mail it to you...I don't know how to post pictures here...LBDemay@verizon.net
I had the same problem, and what I did was install Lamonster highway pegs. Then with my foot resting on the highway peg I can operate the brake with my heel. It's been working pretty well for me.
2022 Spyder RT Limited Sea to Sky Mystery Blue
Yeah, I remember someone else doing that with success, George. That will be my next “try”, if my current “pre-production”, heel lifting option doesn’t work. Mind you, I’m on a ‘21, so the board/brake dynamic is slightly different. I’ll have my foot at the front of the large, upswept ‘21 board, and operate the brakes with my heel from there.
Pete
Harrington, Australia
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
Here's a cheap and easy that might do the job. Remove the rod and drill a same size hole behind the original one in the front yoke and attach the brake lever to it.
