Results 1 to 6 of 6
    Apr 2021
    OHio
    Default Bug removal from radiator
    I figured out a easy way to remove bugs from my 2021 RT LT radiator
    I used a semi straight dental pick
    All I did was insert pick thru the screen and lightly touched the bugs and they fell off of the fins of radiator
    UNREAL
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    One way not to do it is use a pressure washer. Don't ask me how I know. Not on my spyder, but and older motorcycle.
    Active Member Greven's Avatar
    Oct 2019
    Sweden
    Quote Originally Posted by Bangorbob View Post
    Just to clarify and explain for those who dont know why it is a bad idea, Both pressure washers and compressed air are likely to bend the small aluminium fins and thus damage the radiator, if not beeing very carefull.
    Another GOOD method can be to soak the radiator in your favourite remove-bugs-from-paint spray a few times over an hour or two, and then carefully use a long bristle paint brush to poke out the bugs and debris
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    What about just using a shop vac with soft brush attachment?
    "Love 'em all.... Let GOD sort 'em out!"
    2021 RTL Dark Chalk Metallic with comfort seat
    1978 GL1000 w/'75 engine show bike
    1976 RD400c
    Jul 2014
    Mint Hill, NC
    If one purchases and installs Spyderpops' Keep Out The Trash, KOTTS, Grilles one will be surprised at how many bugs do not make it to the radiator fins. Those that do make it to the radiators can easily removed using Greven's method.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Jul 2021
    IL
    I guess I need to look at the radiator area, something I have not yet done since I bought the Spyder. But its only been 3 weeks so I doubt there is much bug build up.
    2021 Spyder RT
    Retired U.S. Army
    Life Member, NRA
    2021 RT , Petrol (blue)
