Results 1 to 10 of 10
    Jul 2021
    IL
    Default Risers - anyone tried them? Can I fit DIY?
    I see that Sling Mods sells risers for the Spyder, and I'm thinking it might make my riding position more comfortable. Anyone here make that mod? Do the cables on the handlebars have to be replaced? Wondering how big a job it would be to install the risers myself.
    2021 Spyder RT
    2023 Royal Enfield Hunter 350
    Retired U.S. Army
    Life Member, NRA
    2021 RT , Petrol (blue)
    Quote Originally Posted by vito1943 View Post
    A few folks here have bought and used " ROX " risers if they had an F-3 ..... go to DennisKirk - snowmobile catalog , they are a lot less expensive ..... Mike
    Sep 2020
    Middletown, NJ
    Lamonster has a 2 in riser block that is far more solid than ROX risers. You will likely have to release the cable clamps on the handlebars to gain the extra slack.
    http://www.lamonstergarage.com/handl...020-lamonster/
    2020 RT base , Chalk White
    Hey Vito, have you looked at this thread?
    https://www.spyderlovers.com/forums/...for-f3-RT-2020
    Could be worth your while to contact & at least talk to Kevin, even if you don't end up buying from him?!?
    May 2020
    Walker, LA
    I have the same riser Kevin is selling that Peter A mentioned above on my F3-S Special and I absolutely love it.
    May 2021
    Northeast Oklahoma
    Just put LaMonsters riser block on my 21 F3-S Special. Easiest mod so far. Took less than fifteen minutes.
    2021 F3S Special Series , Grey / Black / Orange
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    I bought the 2" riser from lamonstergarage and did not have to do anything with the cables. There was enough slack.
    2021 RT Base - Petrol Blue
    Jul 2010
    Las Vegas, NV
    Concur. Did one last week for a lady. Super simple, plenty of wire. She was thrilled.
    Last month, I installed the adjustable riser on a 21 RT. Also simple, works great!
    Joe Meyer
    Feb 2020
    N. Wilkesboro, NC
    OP---It depends what you ride. If you have an F3 or a 2020+ RT, those are good suggestions. You can NOT add risers to a PRE 2020 RT.
    May 2019
    Washington
    Sling Mods has a new riser available for the Spyder F3
