Results 1 to 18 of 18
    Active Member ziggy's Avatar
    Apr 2021
    North Carolina
    Default Ryker won't start !!!!!
    Beautiful day. I decided to ride. Bike won't start. Said insert key. Tried both keys, checked fuses,\.. Called dealer, thinks it's the DSS,
    9 week waiting list !! WHAT!! Waiting for a return call. This means I've got to (1) Buy a trailer hitch. (2) Rent a trailer (3) Take it to Ashville, N.C.
    which is 50+ miles away.
    Active Member RykerRider1959's Avatar
    Jul 2021
    Wisconsin
    Could be as simple as missing one of the starting procedures
    Insert key
    Parking Brake engaged...Up Position
    Right foot depressing brake down
    Touch the start button to engage electronics
    Twist throttle forward
    Hit start button a second time
    Vroooom off ya go...hopefully
    If not
    If the guage pod has nothing, check battery with your charger or take it out and have your local auto parts store put it on their tester...
    Good Luck...
    Apr 2021
    North Carolina
    Quote Originally Posted by RykerRider1959 View Post
    Insert key
    If not
    Good Luck...
    Yep....Did all that 5 or 6 times No joy!
    Invalid Emails
    May 2021
    Ontario,New York
    Please let us know what the problem was when you get it figured out.
    Jul 2020
    Florida
    Did you check the battery (voltage, loose terminal cable)? Do you use a battery maintainer, short trips isnt enough to keep the battery fully charged and a weak battery will cause your symptoms.
    2020 Can Am Ryker Rally Sport Touring Edition
    Apr 2021
    North Carolina
    Quote Originally Posted by RykerRick View Post
    Yes, checked battery, even placed on charger for 8 hours just in case...No joy. Panel shows battery good. Shows insert key, tried both keys.
    Bike garaged, never been washed, never ridden in rain . Tried last night at 10pm...going to try again in the next few minutes....
    Just went out, tried to start 3 times. No joy.. Instrument panel shows EXACT WORDS " CHECK KEY"" then shuts off.
    Oct 2020
    KS
    If you google this phrase a number of things come up that can affect electronic keys, worth a look maybe. "what can affect operation of electronic keys"
    Apr 2021
    North Carolina
    I found an old post mentioned on here , about Spyders DESS KEY CODES AGAIN!!!!! but can't find it here now. Seems it was a very common issue with Spyders in 2015.
    Anyone know about it? Talked about disconnecting the system . I thought it could be info that might relate to my Ryker
    Aug 2020
    Il
    Have you tried disconnecting the battery for about 30 minutes or so, then reconnecting and see if it restarts?
    Apr 2021
    North Carolina
    Quote Originally Posted by Pirate View Post
    No, didn't try that. Thanks, good idea...
    Half an hour later. Didn't work !
    Invalid Emails
    May 2021
    Ontario,New York
    Quote Originally Posted by ziggy View Post
    Did you get the problem figured out?
    Apr 2021
    North Carolina
    No ! Talked to dealer, wants to reprogram keys first. Said it might be a computer issue. Advised to keep it home until they have an opening in the shop .Will call on the 10th or 11th.
    Aug 2021
    FL
    Talking
    I had been looking at changing the key for a keyless start (Slingmods.com $299.95) and in the instruction video it shows how you can by-pass the key landing knob and wiring. It shows how to access the wire harness. You can actually open the panel and see them. Perhaps you can check the connections there or even buy the keyless start and forget the keys!
    Active Member DickB's Avatar
    Jun 2021
    FL
    Quote Originally Posted by apgacivil View Post
    That won't help. The Slingmods keyless system does not bypass the Ryker key - you must install the Ryker key permanently, and the stock key system must be functioning, for the keyless system to work.
    Apr 2021
    North Carolina
    Called Can-Am Roadside this morning. Waiting for return call on when a tow truck will be here to pick up my bike. I had to pay an additional $83.00 for the tow
    above the $200.00 BRP pays. What's a guy gonna do ?
    UPDATE; it's now 2:50PM , no tow truck . Glad I'm not sitting on the side of the road ! This started at 9:AM.
    Update : Day two, called back to the Can-Am number on my Warranty Card........Stated they will investigate and call back.
    Final Update Day two: They sent a text about !030 Today Friday 13th... Stated tow would arrive in 45-60 min. Arrived in 30. Ryker is in shop.
    Apr 2021
    North Carolina
    OK...Dealer called. Problem was defective battery. I put on my trickle charger, it showed battery was fully charged. So I guess that was a false positive ?
    Going to pick it up in the next hour....
    Invalid Emails
    May 2021
    Ontario,New York
    Shame to have it out of commission for so long over just a bad battery but at least it is fixed now.Ride on!!
    Jul 2021
    Wisconsin
    Insert key
    If not
    Good Luck...
    7-21-21
    Better late than never...
