Results 1 to 9 of 9
    May 2016
    Ct
    Default What Coolant to use??
    Trying to find out what coolant to use. Wife put the manual somewhere and can’t find it now.
    Quote Originally Posted by Cvjj1991 View Post
    Unless you want to FLUSH the system .... to be safe I would use BRP's .... Mine is now 7 yrs. old and still tests good .... Mike
    Sep 2017
    Durham,Maine
    Unless you want to FLUSH the system .... to be safe I would use BRP's .... Mine is now 67 yrs. old and still tests good .... Mike
    Wow Mike 67 years old, you sure it dose not need replacing?? What kind do you use, sounds like the brand to use!
    2012 RTL , Pearl
    That was a typo ..... I just corrected it ..... Mike
    Active Member deer30084's Avatar
    Jun 2016
    Tallahassee, FL
    I changed mine with a piece of plastic I gave to dealer. He was nice enough to give me a piece of paper back.
    John F.
    Tallahassee, FL
    2015 Spyder F3 SE6, black
    BRP Driver/passenger Footboards
    BRP Adjustable Passenger Backrest
    Blue Ridge Windshield
    MRA X-Creen Tour, clear, clamp-on
    H4 LED Headlights
    F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
    Easy Brackets
    Leatherworks, Inc. 120 Special Slight Angle Saddlebags
    Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
    2-up rear shock
    Idler pulley kit
    Active Member MrMagicFingers's Avatar
    Apr 2020
    Dartmouth, Nova Scotia, Canada
    Really, any good quality coolant will work fine.
    I just flushed mine and replaced it last week. I mixed up a batch of 40/60 (40% Prestone and 60% distilled water) of the green Prestone. I run that mixture in all my bikes. You can buy it pre mixed as 50/50.
    Flushing with at least distilled water is a great idea too. I also vacuumed out the bottom of the radiator and took out many many little kidney stones. I believe the previous owners just used country tap water. It had heavy mineral deposits.
    It's not like BRP has a special blend or a factory that they produce their own. Of course they want you to get their jacked up ($$$$) products. Same with the oil.
    My 2010 RTS took a little better than 3.2 liters.
    Tim
    Current - 2010 Spyder RTS
    1) Experience is something you don't get until after you need it.
    2) A closed mouth gathers no foot.
    3) IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU HAVE TIME TO DO IT OVER??
    ___
    Horsepower is an illusory mathematical equation; Torque is REAL, and is the source of all good things in the world.
    The problem is not the problem. The problem is your attitude about the problem. Do you understand?
    Please check out my pics!!
    Bossier LoUiSiAna
    Don’t mix colors If/when in doubt just add water
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Active Member T.P.'s Avatar
    Oct 2016
    APPLE VALLEY, MN
    I have used PEAK GLOBAL in my Honda Valkyrie's since 2004, It's a lifetime mix that is Phosphate and Silicate free. (The silicates caused trouble with the Honda 's waterpumps)
    Run that in our Spyders now.
    T.P.
    Jul 2014
    Mint Hill, NC
    ....to be safe I would use BRP's...
    Why cheap it out? If you can afford a Spyder you can afford the BRP coolant that comes cut 50:50 with demineralized water. To do it correctly, pop for a service manual, about $30 online: https://canammanuals.com/.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
