Results 1 to 9 of 9
    May 2019
    Port St. Lucie, Florida
    Default Hard braking pulls right! Anyone else? Ideas?
    I've had a couple of recent instances where I've had to brake fairly hard. I noticed that when I did, the bike pulled hard to the right. Maybe it was something that I did, unconsciously, but am wondering if anyone else has experienced this. It certainly does stop well! I'd just hope it would stop in a straight line.
    -Carsong
    2018 F3t
    2018 F3T , Position 5/ full size Matt Black
    Very Active Member JKMSPYDER's Avatar
    Dec 2012
    Murphy, NC
    It could be a warped rotor or brake pads wearing unevenly.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Spyderpops Brake/Run/Turn Signal LED's
    Lamonster Garage LED Fog Lights and Headlights
    2013 ST-S retired 1/9/16 at 25,061 miles
    2015 F3S sold at 77,565 miles.
    2015 F3-S , BajaRon Plugs Can-Am Red
    Bossier LoUiSiAna
    Quote Originally Posted by JKMSPYDER View Post
    & ez enough to check if was just the one time maybe you did apply additional steering & the stop had u pushing on The bars still not bad in checking brakes & disk
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Sep 2015
    Chilliwack, BC. Canada
    My RTS did that after I had new brake pads installed. Once the new pads settled in, a couple of months later (I use my brakes sparingly) the pulling to the right diminished and stopped. I’d totally forgotten all about it, until you’ve mentioned it.
    If it was me, I wouldn’t worry about it. I’ve had it happen on my cars also. I’m not a brake man but I think your brakes just need breaking in.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Aug 2007
    Greeneville, TN
    I recommend at least one caucus 'Panic Stop' on a good, flat road surface where you have plenty of room and no danger where you can pay attention to what you are doing as well as the Spyder. If it is consistently pulling to one side, there are a few things to check.
    I doubt a 'Warped' rotor in this case since you make no mention of vibration or pulsation of the brake peddle/wheel. It is more likely a sticking caliper on the weak side not doing its share. Check for even pad thickness.
    A hard brake test or two under controlled conditions should verify that you do, in fact, have an issue. I would not let this go uncorrected, for obvious reasons.
    Apr 2016
    Albany NY
    Alignment is also a possibility.
    Active Member Smokes's Avatar
    Jan 2017
    Melbourne, Australia
    I'd check your front tire pressures.
    Andrew
    Melbourne Australia
    2016 F3L Spyder
    Now, wash your hands
    Apr 2019
    Clinton, MS
    My bet would go to one brake shoe worn completely out and its grabbing on the metal backing plate. They don't always make a noise when bad.
    Aug 2020
    Minsk
    Where can I find a repair kit for brembo front calipers?
