Results 1 to 21 of 21
    Active Member RTSJohn's Avatar
    Feb 2019
    Killeen, Texas
    Default Oh that dreaded spark plug failure
    Took the Spyder out for a ride a few days back and "oh my gosh" !! The power was awful and it sounded as if something was terribly wrong. Turned around and headed back home with no change. Stopped and it felt as if there might have been a miss, but more like one cylinder wasn't firing at all. Could it be plugs?? Coil pack? Something else?? Ok, I figured at 21000+ maybe it could be plugs so I started there. Got new plugs and started searching for information to aid in doing the work myself. After much consideration I decided to bite the bullet and take to a local shop and give them a try. When I described the issue they told me it was most likely plugs. They have found that to be the case is several Spyders in the past few weeks. I took it to them yesterday and they called this afternoon and said it was now running great. Plugs were shot. I picked it up and it ran better than it has in weeks. Tomorrow it will be getting a road test for certain. Time for Wind Therapy !!!
    2014 , yes Pearl White
    Durham,Maine
    I wish it was a easyer job to do, I would like to change the wires and plugs in mine!! But I fear I will take it to a shop, I just don't know if I am set up for that much tear down!!
    2012 RTL , Pearl
    Feb 2019
    Killeen, Texas
    That was my deciding factor as well. I don't regret the decision at all. I'm a full time RV'er and don't have a place to complete that undertaking.
    Jun 2021
    South Carolina
    i posted a pic of changing my plugs, after thread , MAJOR SERVICE, if you want to see what you have to remove to change
    It was a little intimidating at the beginning of the job when I changed mine at the 56K service but I just took it slow and steady and it worked out fine. I'm surprised yours went south around 21K; my originals made it through 28K, never missed a beat and I've read of others who've gone easily past that interval with no problem. I changed to Bajaron's iridium ones. With arthritis getting both my hands the Spyder tech at my dealership will do the next ones in about 11K.
    Quote Originally Posted by RTSJohn View Post
    " 21,000 + " miles ...... I'm more than a bit skeptical on this ..... I have 60,000 + on the same engine with original plugs, coil packs. wiring etc. and to date no plug issues, that I can detect .... still getting the Same good mileage ( 39 mpg's ). .... I have little faith in the Expertise that a lot of dealer Tech's have shown ..... JMHO .... Mike
    You beat me to the question BK.
    Yes, they are a "bear" to change out. The two places that I talked to about changing mine out at 40K said they should be good until at least 60K.
    Sep 2014
    USA
    21000 miles and you needed plugs. Those plugs they put in the Spyders are normally rated for 100k miles. Mine are around 34 K and have no plans on changing them soon.
    Jun 2011
    Alamogordo, NM
    In a lot of cases, plug life will depend on how the vehicle is driven
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Feb 2019
    Killeen, Texas
    I was troubled as well... but I can assure you one plug wasn't firing at all ... period. New BajaRon plugs and it is now running like a new ride.
    I had the "one plug" not firing on my 2010 RT (twin cylinder). It turned out that one wire was shorting out from rubbing against something. It started happening when I got caught in a rainstorm. The dealer replaced that and no more issues for me. I traded that Spyder off at 36K miles and the original spark plugs.
    Sep 2016
    Yukon, OK
    2016 RTL, I still have the original plugs at 84,000 and it is running like a top. I have heard of some of them going past 120,000. Luck of the draw? or how they are ridden? I am dreading when I have to have mine changed.
    2016 RTL , Orbital Blue
    Quote Originally Posted by Chiisai View Post
    Iridium plugs have a very long " use life " ..... jmho .... Mike
    Registered Users Motogordo's Avatar
    Jun 2011
    Delanco, New Jersey
    July 21,, 2021
    Speaking of spark plug replacement. I had a 2016 Smart Car with about 70,000 miles, running fine. I asked the Mercedes dealer what it costs to replace the plugs. They said $550 . I said " what ." They told me they have to take half the car apart to replace the 3 plugs. The following day I sold the Smart Car on Facebook Market Place. They buyer came over with cash and off he went. It was a great car.
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    Just want to add my thoughts to this matter, If you use the throttle while starting the engine , you will shorten the sparkplugslife dramaticly, never use the gaslever while starting these engines.
    They will get flushed with unburnt fuel, with no temperature to get rid of the excess... jmho
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Nov 2019
    Kansas
    How much did the Dealer charge to do the Plug changes?
    Feb 2019
    Killeen, Texas
    a
    Quote Originally Posted by acdcking12 View Post
    The charge was 3.1 hours = $283 . Would I pay that again? You bet ya !! I drove up on my cabbage truck, fell off, and watched the work as last plug was pulled. It was ding dong dead. "short life" for what is normally a "Long one" .
    Jun 2015
    Hampton Roads, VA
    I worked on a friends byke that was jerking trying to take off. In the end was a cracked plug! Of course on the right side. Factory plug too. No idea why, never has seen this before. Put in the the fine tip version. Was a 2013 ST-S VTwin.
    Aug 2012
    Central Coast, CA
    Plug life is super variable. Iridium plugs in automobiles can last up to or over 100k miles, but rarely that in motorcycle type engines. I assume that's because of the higher stresses: horsepower per cubic inch, etc. For example, in BMW motorcycles they recommend changing plugs every 12k miles, which is incredibly short even for non Iridium tipped plugs. Owners frequently change to the Iridium plugs to extend the plug life, but even then many report those only last in the range of 24k miles. In some of the BMW bikes I've owned the OEM plugs were toast at about 10k miles, while others lasted much longer. In a Suzuki motorcycle (dirt bike) I used to own the Iridium plugs only last a couple of thousand miles before failing. Why was a mystery, it just did.
    Anyway, with the Spyder, my 2014 RT the plugs were completely toasted at 36k miles and should have been changed much earlier, like the OEM recommended mileage. And, yet as we've read above many Spyder owners report much longer plug life, so that's why I say they're variable.
    2020 RTL SE6
    Sep 2014
    USA
    As mentioned, there are several reasons that spark plugs do not last nearly as long in a Spyder (or most motorcycles) as they do in cars. For one thing, it is not uncommon to be turning 3 or 4 times the RPM in a motorcycle. That alone can cut mileage in 1/2. It is also not uncommon to run WOT or generally harder on a motorcycle than you do in your car. Cars generally do a lot more steady throttle, cruise control type miles than does the typical motorcycle that more often heads for the back roads and twisties. Couple this with how much a set of worn spark plugs affect the HP and efficiency of a motorcycle as opposed to a car. And you end up with a much shorter life. You really can't compare the 2. They are only similar in that they are an internal combustion engine.
    In a race car, spark plugs last just 1 race, in most cases. Dragsters may only get 1 run (1/4 mile) from a set of spark plugs. Just to represent the spectrum. Don't try to compare your car to you Spyder. They are very different.
