Results 1 to 12 of 12
    Registered Users Motogordo's Avatar
    Jun 2011
    Delanco, New Jersey
    Default Metal valve stems
    July 17, 2021
    I happen to stop by my Spyder dealer yesterday and noticed that Honda is now using 90 degree metal valve stems on their Monkey and another little cycle. One is $3000 and the other is$4000. Smart move for Honda customers and now we need Spyder to do the same. IMO
    Motogordo
    Mar 2013
    Marion, Arkansas
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    GoldWings had metal stems '01-'17, but they went through a poor rubber flange at the wheel that failed just as fast as all-rubber stems. Many GL1800 folks switched to a "Patch Boy" all-metal (rubber seal) stem.
    1976 RD400c
    Feb 2019
    Portland, Oregon
    I doubt it would cost BRP 5 cents more to install slightly longer valve stems on the front wheels. How much nicer that would be for checking and airing up tires. My tire guy did that when I had the Federals installed.
    Jul 2013
    Conn.
    Default Metal Stem
    Quote Originally Posted by Motogordo View Post
    July 17, 2021
    Motogordo
    I’m schedualed to have a new rear rim and tire installed, I had them put a metal stem on. I use the garmin tire pressure sensor and Garman recommends metal stem.
    2017 RTL , Grey
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    56 years of MCing and driving.
    Never had a rubber valve fail. EVER!
    For MC the valves get changed when the tires get changed and same with the 4 wheels.
    As the old saying goes, "if it ain't broke. don't fix it!"
    At 72, I'm sorry that some youngsters gotta get down on the ground and maybe get a little dirty.
    Well, that's life, suck it up!
    Believe me it's a lot harder getting back up for me, then many of you.
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by PaladinLV View Post
    And at 85 I'm doing all my maintenance and mods - just made my own belt guard - and getting up ain't easy for me now, but I manage. But at 72, I was swinging from the rafters and doing LD rides on a Victory. We all age differently, my friend. Good health to you.
    Active Member Papa103's Avatar
    Aug 2019
    Maine
    When the auto manufacturers went to TPMS, most of them went to a metal (aluminum) valve stem. 5 years down the road the aluminum corroded and the stem leaked. TPMS sensors are approximately $50. Now most all TPMS sensors are back to rubber. Must we learn this all over again? What do they think a metal valve stem will do better than rubber?
    2021 RTL Chrome Deep Marsala
    HELI Bars
    Garmin Zumo XT
    USB power port
    Front fender lights & Sequential turn signals
    Front LED Auxiliary light
    Flashing brake module TricLED
    Baha Ron sway bar
    belt tensioner
    RLS muffler
    2021 RT Limited , Marsala Red
    Active Member trong's Avatar
    May 2020
    West Valley City, Utah
    On my Rebel 1100, Honda use 90 degree alloy valve stems, easier to check tire pressure and add nitrogen in the tires, (I use 78% nitrogen in all my tires.) I couldn't ask for more.
    Cheers!
    ‘21 Honda Rebel 1100 DTC Burgundy
    ‘13 Spyder RT-L Pearl White
    May 2020
    Quote Originally Posted by Papa103 View Post
    Rubber valve stems will get brittle and crack, It happened to me on a 4year old stem.
    Aluminum stems get corroded. I don't really think ones better than the other.
    if you have TPMS on your car(s), most tire stores will replace aluminum stems for $12 ea. when you get new tires. Costco charge $3.
    Dec 2018
    Elanora, Qld, Australia
    There is good advice in an earlier post to change the valve along with each and every tyre change. Tubeless valves cost zip and take moments to replace. Leaking old valves can cost a whole lot more if the tyre deflates out bush.
    There is usually another way. 2020 F3Ltd.
    2020 F3 Ltd , Brake Pedel lowered. Liquid Titanium
    Clinton, MS
    Quote Originally Posted by trong View Post
