Results 1 to 18 of 18
    Aug 2015
    Cleveland, GA
    Default Powering a GPS from the front glove compartment USB
    Has anyone tried to power their GPS from the USB cable provided in the front glove box above the dash?
    Pete Tamblyn
    Cleveland, GA
    2020 F3 Limited (black)
    Time Out XL1800 cargo trailer
    2019 Royal Enfield 650 Interceptor
    2018 Kawasaki Versys-X 300
    2013 ST (sold)
    2015 F3-S SOLD
    2014 RT-Limited (cognac) SOLD
    Member 65cabriolet's Avatar
    Sep 2019
    Brighton, CO
    I can only speak of my 2021 RT LTD. My Garmin GPS sees the computer on the bike if I use a standard USB cable to connect and goes into maintenance mode (map loading mode), so I opened up the cable and cut the green and white wires (data connections) leaving only the red and black wires (power and ground). This only sends power to the GPS and it now functions normally. I have another standard cable I use to connect to my computer for updates.
    Active Member Indyron's Avatar
    Apr 2013
    Sunbury, OH
    Yes, I purchased the cable directly from Garmin and it works just fine on my S2S
    2021 Sea to Sky, 2013 RT Ltd, 2005 Bombardier Outlander ATV
    Aug 2020
    Georgia
    You may have a hard time finding one advertised as such but some of the USB cables are for power only. They tend to be a little smaller outside wire diameter than the ones that are data and power.
    Apr 2013
    South Carolina and Florida
    Quote Originally Posted by Indyron View Post
    Can you tell me what the cable is called or how you found it. I have searched the Garmin site without success. I am trying to connect a Garmin DriveSmart 60 to the front USB port.
    2013 RTS SE5
    2013 Kawasaki Vulcan Nomad 1700
    Apr 2013
    Sunbury, OH
    Quote Originally Posted by Huddleston View Post
    The cable came with my Garman GPS
    Active Member USAF's Avatar
    Aug 2022
    NY
    Try This one. https://www.ebay.com/itm/19422017561...Cclp%3A2047675
    2022 Spyder RTL
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by motoswami View Post
    We use a data blocker on the USB from the glove box, less than $5. a piece on Amazon, That just gives the power and doesn't hijack your equipment. .....Bill
    If in Doubt, Don't Do It!
    Feb 2020
    illinois
    I have a 2022 F3L Special and use a Garmin powered from the frunk accessory power connection and have a bluetooth enabled device from Lamonster powered from front glove box connector which gives Garmin communication to bike speakers using the aux. setting.
    Danbury Connecticut
    Quote Originally Posted by 65cabriolet View Post
    Quote Originally Posted by Knizar View Post
    Yes, I agree totally.
    Cutting the data wires in the USB cable is a very clever solution (I'm assuming you cut the Garmin cable, and not the bike cable). but it's a bit extreme.
    I also use a data blocker on the USB, and you can power anything from the USB port. I've got a double USB to power our SENA units when the batteries die.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Active Member mcalva's Avatar
    Nov 2016
    Viladecans, Barcelona, Catalonia, Spain
    Just a doubt. Power from globebox USB is 5,3 V. and Garmin GPS needs a 12V power wire. Is this correct? If yes maybe It shoudn't go.
    2018 Spyder F3 Ltd
    2018 F3 Ltd. , Black/Dark
    Sep 2020
    Middletown, NJ
    If it's a Garmin GPS the USB port can power the unit (5v) directly but the cradle with direct wire uses 12v and drops the voltage to the mounted GPS.
    2020 RT base , Chalk White
    Harrington, Australia
    Quote Originally Posted by mcalva View Post
    Yes, power is limited, mcalva. I’m not sure how/if it would affect a Garmin, but there have been several reports of the glove box USB being unable to charge the larger draw “plus” phones.
    HeliBars Handlebars
    Kenda Kanine rear.
    Nov 2016
    "If it's a Garmin GPS the USB port can power the unit (5v) directly but the cradle with direct wire uses 12v and drops the voltage to the mounted GPS."
    Ok. So, depending on the Garmin you would to connect, you will have to open the door ( Zumo 660) and GPS will not go or remove the waterproof protection to show the USB port.(Zumo 590 and XT)
    2018 Spyder F3 Ltd
    Sep 2020
    Middletown, NJ
    Yes, which is why the direct wire from 12v to cradle is the designed method. The USB is normally only used for off-bike charging or PC hookup but can work as a backup power source..
    Feb 2016
    Quote Originally Posted by RayBJ View Post
    I agree completely. Why would you not use the dedicated gps power supply on the bike and keep the usb freed up for others things?
    2020 RT Limited , Marsala Red
    Sep 2021
    Fredericksburg, VA
    Totally agree with Jetfixer.... On the F3 its located here
    RiderDuke
    My Ride
    2021 Glacial Blue Metallic F3-T
    Feb 2022
    New Zealand
    Thanks for that picture. I will pull the cover and locate it. Is it a USB plug style?
