Results 1 to 25 of 30
    Active Member RobDekker's Avatar
    May 2021
    New Brunswick, CANADA
    Default Shout out to Monster Fuel Injection.
    I received the brain back today and installed it back on the bike. Wow….what a difference a stage 2 tune makes!! Almost too much power. LOL
    Kudos to Monster Fuel Injection!
    https://www.monsterfuelinjection.com/spyder
    2021 Spyder F3-S Special Series
    Monster Fuel Injection Stage II
    K&N Air Filter
    Lamonster Cat Delete Pipe with Baffle
    Akrapovic Sinister Exhaust
    Ultimate Floorboards
    Baja Ron’s Anti-Sway Bar Kit
    Elka Shocks Stage 3 Front, Stage 4 Rear
    F4 Customs 32” Windshield
    Pedal Commander
    Lamonster F3 Brake Rod
    Shad SH36 Side Cases
    Crampbuster
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by RobDekker View Post
    What is your exhaust set-up? What are your thoughts on going with a Stage 2 and keeping the stock muffler, but having a cat delete (RSL's with the resonator)?
    How much did you pay? If you don't mind.
    May 2021
    I have a Lamonster cat delete pipe with baffle installed. I’m running the stock muffler until the Akrapovic Sinister muffler shows up. I also have a K&N air filter installed. Price in Canada is CAD$550 plus tax and shipping.
    K&N Air Filter
    Pedal Commander
    Crampbuster
    Nov 2019
    Kansas
    From the point to sent it in, how long before you got it back?
    May 2021
    10 days in total.
    K&N Air Filter
    Pedal Commander
    Crampbuster
    Northern Kalifornia
    Is Wick-et any faster?
    indpls in
    for you probably
    Aug 2019
    TX
    Wickit will be about 1 week for you in the U.S. Just got my Daytona tuned by them.. They have a 2 day turn around and shipping time..fun times to be had. can't wait to see how it reacts to the K&N filter. It does feel like it's getting stronger. I have the Akra Sinister pipe with RLS cat delete and the bottom end you lose with the cat delete is gained back and some with the stage 2 tune.
    Feb 2020
    CT and ME
    You can get the MyGenius handheld tuner device from Monster. They provide the tunes and you can load them yourself. No need to remove and ship the ECU. Takes about 5 minutes or so to change them.
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
    Aug 2020
    Lake Sam Rayburn Texas
    How much does the MyGenius cost?
    Northern Kalifornia
    Better check but I think the handhelds are for late models only.
    Feb 2020
    CT and ME
    MyGenius is $350.00 Works with 2017 to 2020 models. (may very well work with 2021 but that's what their website says.)
    My Mods:
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Viking saddle bags
    Third pegs
    Mad Stad windshield
    Garmin Zumo XT
    Heated gear wiring
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by Yabbadabbadoo View Post
    $350 + the costs of the maps.
    2022 RT Sea To Sky
    Jan 2021
    Descanso, CA
    RobDekker -- didn't you also have to make extensive changes to your airboxes too?
    Aug 2019
    TX
    Quote Originally Posted by BertRemington View Post
    The air filter cover is modified by Wick-it to allow better air flow to the engine. I wouldn't call it extensive as it's just 2 1" holes in the cover..
    Dec 2015
    Oakley Utah
    I've noticed that quite a few people on this forum are using 87 octane fuel rather than the recommended higher octane. Is this true also for those who have done the ECU flash? I notice Monster specifies 91 octane;
    "Fuel Octane: Requires 91 octane pump fuel. 93 - 94+ pump fuel can be used and will see automatic benefits as the
    ecu will self adjust. (ecu is very dynamic with well implemented use of oxygen sensors and knock sensors)
    Note: 89 or 87 can be used in an emergency. If used, stay below 50% grip throttle and don't lug engine in a high gear
    with low rpm. Keep engine rpms higher (5000+rpm) only using low gears. The throttle opening should never outpace
    engine rpm (load engine). Cycle fuel tank before riding normal again.
    Always use 91+ on stage 2 setups."
    2014 RTL Platinum
    May 2021
    Monster FI modified the air box lid by drilling two one inch holes.
    K&N Air Filter
    Pedal Commander
    Crampbuster
    Aug 2019
    Stoughton, WI
    Once you get either the stage 1/2 flash or PV map/tune, it should be 91+ octane all the time. In addition to fueling tables, new maps also change timing tables too...
    2022 RT Sea To Sky
    Aug 2019
    TX
    87 octane will ping on a stock byke in higher RPMs. You should really only run min 91 octane although some people do run low grade. definitely min 91 with a tune whether stage 1 or 2. I got some bad gas on my last fillup and noticed my spyder reacting to it. Sucks I didn't see it until after putting the nozzle in the tank and seeing it pour in. The byke ran fine, but I could feel the computer adjusting. I typically only run 93.
    Mar 2021
    Arizona high country
    Just returned from a 3600+ mile trip in hot weather. Most of the riding was highway and interstate speeds. I ran 87 octane and had no pinging of any kind. Spyder ran great and average 34.4 MPG for the trip.
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by rjinaz86323 View Post
    With a ECU flash?
    2022 RT Sea To Sky
    Mar 2021
    No. Stock ECU
    Northern Kalifornia
    Quote Originally Posted by Bottomline2000 View Post
    I carry a small bottle of octane boost on my spyder all the time. If I accidentally get a tank of crappy fuel I can add the bottle of octane boost. Helps to stop that pinging. You can find that stuff on the counter of just about any motorcycle store.
    Jan 2021
    Descanso, CA
    RobDekker and Bottomline2000 -- apologies for my confusion but is the two 1" holes modification done to the air filter cover (which has 3 screws) or the primary air intake silencer? And Wick-It says the air box modification is for Stage 2 while Monster says both stages and they are different -- can you speak to that? Thanks. PS I'm liking the Stage 1 charts -- will be running stock exhaust system as heat and weight are not an issue and it keeps the neighbors happy.
    Aug 2019
    Stoughton, WI
    Yes to the cover.
    2022 RT Sea To Sky
