Results 1 to 14 of 14
    Active Member Micnice10's Avatar
    Jan 2019
    Rochester, MA
    Default Ryker Bogging down, back-firing, and shutting down! Any DIY suggestions?
    Looking for some help…2019 Ryker 900 6k miles…Today my Ryker began boggin down
    Back firing and then shut down…started back up…was fine for a little and then started
    Bogging down again…added some Sea Foam to tank, probably only got 20 miles with
    It before boggin again so headed home…any DIY suggestions before I bring to dealership??
    No warning signs on….
    Nov 2016
    Upstate NY
    Try loosening the gas cap and then riding. It sounds like the gas tank is not venting. If thats the case, then you need to figure out why. Gas cap? EVAP system?
    2021 Sea to Sky RT , Highland green
    Jan 2019
    Rochester, MA
    Thank u, but no gas cap on the Ryker…
    May 2009
    Connecticut
    CVT air filters get dirty real quick . Won't show unless you take the filter out and spread the layers.
    Sea Doo GTI-SE 90 Jet Ski!!
    Jan 2019
    Rochester, MA
    Thanks, will clean filters! Any recommendations on clean methods?
    Dec 2013
    Quote Originally Posted by Micnice10 View Post
    You REALLY don't want to try to 'clean' the OE Paper elements - just REPLACE them!
    It might even pay to 'replace' them with K & N Oiled foam elements instead of paper - longer lasting, cleanable, and arguably a bunch of other benefits too!
    Last edited by Peter Aawen; 07-12-2021 at 06:00 PM. Reason: agruably!? Finger trouble! ;-/
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Jan 2019
    Rochester, MA
    Thank you! K&N it is! Hopefully this helps!
    Jun 2015
    Ritzville, Wa
    Please report back with results.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Jan 2019
    Rochester, MA
    Update, also added StarTron to fuel per dealership recommendation and changed CVT air filter with K&N filter
    (K&N for air, left side is ordered). Went for a 30 minute ride (back roads and quick 8miles hwy) and ran great!
    Hopefully all is good going forward! Appreciate the help!
    Jul 2020
    Florida
    Glad to hear that you got it worked out, thanks for the update.
    2020 Can Am Ryker Rally Sport Touring Edition
    Jan 2019
    Rochester, MA
    Final update. Brought to dealership because still was having bogging down issue,
    It was the oxygen sensor. Bike still under warranty so got it fixed free of charge!!
    Thanks again for all the input!
    Jun 2016
    indpls in
    fuel pump ill bet
    Jun 2015
    Ritzville, Wa
    Frankly, I wouldn't try to clean them. Just replace it. It might even be wise to spend a little more and replace with the K&N filters, much better.
    Greg Kamer
    Active Member DickB's Avatar
    Jun 2021
    FL
    Glad you got it fixed. BTW the oxygen sensor is part of the emissions control and is warranted for 5 years or 30,000 kilometers (18,641 miles).
